Need help
Old May 28, 2007 | 05:40 PM
VIS250P's Avatar
Default Need help
Last week, I was riding to bank and something happen to my car.. When I was accelerate, the whole front end shaking and I drive normal, it ride smooth... So I went home and jacked up the car.. I look underneat the car and find the problem.. Three of the motor mounts were broken (rear motor mount, passenger and driver lower motor mount).. So I bought three brand new motor mounts and then installed them on the car.. AFter that, I went to test drive and it still shaking... IT still bothering me.. I went to Discount tires to rebalance the tires and then I test drive.. It still shaking again... I dont know what is going on.. I double check the mounts and they look fine.. Dont ya think it is tranny or the axles? I replace axles since December... I dont know.. SOme of my friends said it could be transmission (LSD) or the axles? Does anyone had this problem?
Old May 28, 2007 | 06:37 PM
red integra lsr's Avatar
Default Re: Need help (py)
my car did the same and it was the axles. it worth a try
Old May 28, 2007 | 06:55 PM
VIS250P's Avatar
Default Re: Need help (red integra lsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red integra lsr &raquo;</TD></TR><TR><TD CLASS="quote">my car did the same and it was the axles. it worth a try
Yea I have other person said same thing.. I will take them off and get another brand new axles.. They are about 5 months old.. That is weired...
Old May 28, 2007 | 06:57 PM
JjuuN R's Avatar
Damn, must be doing a lot of drag racing?
Old May 28, 2007 | 07:08 PM
citrus3000psi's Avatar
the key word is accelearate and you didn't give us any information about aceleration. Some defintion might help us determine the problem.
Old May 28, 2007 | 07:50 PM
Chris F's Avatar
I bet you broke your axles with your motor moving around too much!
Definitely sounds like axles, I had the same issue on my hype-zomg-I-washed-my-car-again-today-R.
Try NAPA new axles. Like $120 and they work.
-Chris
Old May 28, 2007 | 08:52 PM
VIS250P's Avatar
Default Re: Need help (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I bet you broke your axles with your motor moving around too much!
-Chris</TD></TR></TABLE>
Hmmm Let see what the problem? Thanks for answer..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">the key word is accelearate and you didn't give us any information about aceleration. Some defintion might help us determine the problem. </TD></TR></TABLE>
Im sorry my mistake.. I thought the spell is right but ooop!!!
kenttouchthis
Aug 24, 2008 04:09 PM
IVGattaBeDreaming
11
Sep 5, 2006 11:42 AM
SlammedDC2teg
Jan 15, 2006 02:43 PM
turbob16ef
Nov 12, 2005 01:13 PM
Turbo-Tec
21
Jun 17, 2005 06:31 PM
