What year crx......
Ok I've got a 91 HF CRX that had 120k on it and the front end had been hit hard but I spent some cash when I got it and had it straightend....after doing some work on the rear suspension (toe and camber mounts) tonight come to find out that the rear beam has been replaced also and incorrectly at that.
After much swearing and cussin considering all the work I've put into my swap and repainting and body work to get the body straight on it I think I'm done with this car.
I'll be stripping this thing and getting rid of the shell. So I need to find another CRX to put all this into. I get to start all over with the bodywork, paint etc. BLEH!
I wanna know if it were you what year, model would you go for?
I'm thinking a 90-91 si (a sunroof might be nice) but is there a better bodystyle or one more sought after? I know wheres there's a 88 shell with the seat belts not in the doors...dunno if these are a better car or if an si would be better.
Comments welcome!
88 shell with the pillar mounted seatbelts is a good deal lighter then a 90 or 91 si.
few hundred pounds to be exact.....
you really have to decide for yourself, however i will say if you get a DX you have more annoying wiring to tangle with to do swaps and whatnot since its all DPFI.
What ever car/shell I get will have my custom wire harness installed into it....I hardwired my H22 so I could use all the factory wiring that was on the motor...had to run a few extra wires and used some of the old wire harness...its nice and tucked away.....anyways
I was sorta wondering about the weight of the 88....that and I cant recall seeing very many crx's with the seatbelts not in the door.....when were they made the other way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx22 »</TD></TR><TR><TD CLASS="quote">
I was sorta wondering about the weight of the 88....that and I cant recall seeing very many crx's with the seatbelts not in the door.....when were they made the other way?</TD></TR></TABLE> only 88 had them...and in regards to the weight, you may wonder no more...
"see below"
1985 Honda CRX Si MT 1883
1985 Honda CRX DX MT 1819
1985 Honda CRX HF MT 1713
1986 Honda CRX Si MT 1953
1986 Honda CRX DX MT 1819
1986 Honda CRX HF MT 1713
1987 Honda CRX Si MT 1978
1987 Honda CRX DX MT 1865
1987 Honda CRX HF MT 1713
1988 Honda CRX Si MT 2017
1988 Honda CRX DX MT 1922
1988 Honda CRX HF MT 1819
1989 Honda CRX Si MT 2138
1989 Honda CRX DX MT 2048
1989 Honda CRX HF MT 1834
1990 Honda CRX Si MT 2174
1990 Honda CRX DX MT 2103
1990 Honda CRX HF MT 1967
1991 Honda CRX DX MT 2103
1991 Honda CRX HF MT 1967
1991 Honda CRX Si MT 2174
"see below"1985 Honda CRX Si MT 1883
