1990 CRX SI MICHIGAN
I have a 90 crx si that I am looking to sell. It has 132000 miles on it and is in average shape for its year (rusty quarters and random spots), its yellow. Here is a list of new parts that have been installed since 1-1-07 New exedy oem replacement clutch with fidanza 7.5lb flywheel, Header, Testpipe and 2.5in pipe all the way back, I installed a short shifter, cold air intake, new plugs and accel wires, 4 new falken tires on oem 14in si wheels, new battery, and all new oem brakes pads and rotors front and rear. This is the only crx si I have personally seen without a/c from the factory. The only bad things I know about the car its over about 3/4 full the gas tank leaks but this car gets well over 35mpg and the outer tie rods need to be replaced I have new ones just havent replaced them. Most of the interior is there the hatch cover is there but split and the front speaker grills are missing. I would like $1800 obo w/ a d16z6 head with fresh valve seals, adjustable cam gear, gates racing timing belt, arp head studs, and a adjustable fpr. or $1600 obo without. Thanks for looking
Modified by 94b16teg at 7:28 PM 5/30/2007
Modified by 94b16teg at 5:58 AM 5/31/2007
B16smku
Feb 5, 2013 09:18 AM
amthompson
Jul 8, 2008 06:57 PM
