Civic Si fuel pump same as GS-R/ITR?
Old May 28, 2007 | 03:08 PM
White98LS's Avatar
Default Civic Si fuel pump same as GS-R/ITR?
I'm upgrading my dead LS fuel pump to a GS-R/ITR. I have found someone local with a Civic Si pump... I have read these are the same as GS-R/ITR (and the Walbro kit has the same part # for both) but when I looked up the OEM part numbers, they are different. Does the Civic Si pump fit the LS/GS-R/ITR? I know the Si pump is supposed to flow the same as GS-R/ITR, but does it actually fit?
Old May 29, 2007 | 06:59 AM
White98LS's Avatar
Default Re: Civic Si fuel pump same as GS-R/ITR? (White98LS)
Need an answer within the next couple hours!!!
Old May 29, 2007 | 10:52 AM
92_civic's Avatar
the SI will work...but why not get the walbro? car will thank you for it
Old May 29, 2007 | 11:07 AM
White98LS's Avatar
Default Re: Civic Si fuel pump same as GS-R/ITR? (92_civic)
Thanks for the info.
No need for a Walbro. I'm running 40% higher fuel pressure than stock on my LS with no plans for any significant increase. GS-R/Si/ITR pump flows ~64% more than the LS pump. I can get a used one locally for $25, or new for $50. Problem solved.
Project X
Jan 4, 2006 08:25 AM
itr_18
Oct 21, 2003 11:10 AM
Kid1320
Oct 7, 2003 09:52 AM
muse
Aug 15, 2003 11:11 AM
fowler!
10
Sep 21, 2002 07:13 AM
