i need opinions on this much needed rebuild
Old May 28, 2007 | 02:52 PM
ProjektCRX2's Avatar
Default i need opinions on this much needed rebuild
well since my b18c is pretty much leaking from every possible seal im thinking about rebuilding it and sticking all this stuff in it...tell me wut u think and if im missing anything....
head:
skunk2 valves (std or hi comp)
skunk2 dual valve springs
skunk2 ti retainers
skunk2 pro 2 cams
already have the skunk2 IM
I have a type r thottle body but might get a skunk2 68mm or bigger
block:
itr pistons
stock rods and crank
acl rod and main bearings
replacing every seal and gasket from top to bottom
Old May 28, 2007 | 03:22 PM
garageEF's Avatar
Default Re: i need opinions on this much needed rebuild (ProjektCRX2)
sounds good...get to work
Old May 29, 2007 | 08:28 AM
Andy R's Avatar
if your replacing the valves, you should get the valve seats worked.
and while its being machined, port match the intake and exhaust manifold to the head.
contractkiller
Jan 29, 2008 01:27 PM
datap1mp
Aug 4, 2004 10:41 AM
b16powwer
Nov 11, 2002 10:17 PM
