need help. and fast. clutch problems
i have a 95 acura integra special edition manual trans. when the car is started and clutch in it will not go in gear. but when i turn the car off and push the clutch in it will go in every gear. now with the car started and in neutral with the clutch in, the clutch shakes really bad. and when i start the car in first it wants to go by itself with the clutch in. can anyone help me please.
thanks,
Jimmy
thanks,
Jimmy
Well... it should not surprise you at all that your clutch is bad. Time for a new one.
Your symptoms sound like what I had a while ago. Prob. the clutch disk/pressure plate etc. are shot.. Mine, it was that plus a cracked flywheel I believe. I had changed my master cylinder and it hadn't fixed anything - you just need a complete new clutch, it sounds like.
lopezchris21
25
Nov 19, 2023 08:24 PM
