96Accord losing Coolant help?!?!
Old Jun 3, 2002 | 06:58 AM
Shft@9GSR's Avatar
Default 96Accord losing Coolant help?!?!
It's leaking coolant from someplace. Can't tell if it's from the radiator or what. Haven't had time to take a good look at it. Until later tonight after I get off work... Anyway. I was just wondering...
There is the radiator, and it looks like some other cooling device that sits in front of the radiator.
What is the cooling device that sits in front of the radiator?
trans cooler (it's auto), oil cooler, some sort of cooling device for the AC? knowing what this is would help me out lots. From a quick look, it seems that I hit a small bird sometime and it looks like that it's leaking from the cooling device in front of the radiator, but I don't know what it is and I don't even know if it actually flows coolant, oil, or trans fluid. I would really like to know before I try removing the radiator and this other device.
Any info would be greatly appreciated.
thanks in advance
[Modified by Shft@9GSR, 3:59 PM 6/3/2002]
Old Jun 3, 2002 | 07:11 AM
Gennady's Avatar
New User
Default Re: 96Accord losing Coolant help?!?! (Shft@9GSR)
I thinks its an AC system cooling element in front of the radiator.
Old Jun 3, 2002 | 08:31 AM
4doorH22's Avatar
If you're leaking coolant and seeing puddles, they should be green and smell like syrup. The thing in front of the radiator is the A/C condenser. If that was punctured your A/C would not blow cold air.
Old Jun 3, 2002 | 09:06 AM
Shft@9GSR's Avatar
Default Re: 96Accord losing Coolant help?!?! (4doorH22)
Ok so from what you guys are telling me is that the AC condenser is what sits in front of the radiator.
then the problem is definately coming from the radiator.
And yes there is coolant on the ground. And yeah it smells like coolant.
thanks for the help.
this will definately shorten up the time. It's a snap removing and installing a new radiator. Had to do the same thing on my GSR. (Honda radiators suck! IMO. End caps always crack).
Thanks again.
Old Jun 3, 2002 | 09:13 AM
4doorH22's Avatar
Easy as pie.
milkwasabadidea
Jan 8, 2011 10:22 AM
C00kiemunstr
Oct 3, 2008 05:05 PM
slikz714
Jul 12, 2006 03:40 AM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
