Spoon twin blocks on EG6
I have a set of twin blocks to go on my car, but I cant find any compatable rotors. Im sticking with 4 x 100mm pcd but need 11.2" rotors. I think spoon do some for this conversion but I cant find a part number. Does anyone have it?
Or does anyone know of another brand of rotor I can use that is recomended? I just want a plain rotor, not drilled or anything.
And I dont want to start getting DC2 disks redrilled either, I want disks that I can buy off the shelf for practicality.
Thanks in advance
Thanks in advance
I think http://www.fastbrakes.com sells the 11" prelude rotors custom made with a 4x100 bolt pattern. these might be what you need.
edit:
Here you go: http://fastbrakes.com/shop/pro...d=873
edit:
hes talking about these
http://www.nengun.com/spoon/twin-block-caliper-set
Spoon twin blocks as in twin block brake calipers!!!
Sorry if I caused any confusion.
Will have a look at that site, thanks.
PS its for an EE8 but I put this post on the EG section as well hence putting EG6 in the title!!
i have an eg6 with the twinblock calipers.
that time i ordered also their 282mm rotors for the conversion.
they are blank 4x100 rotors made by honda, probably is from the prelude, older model.
Also needed a 5mm inner disck spacer, so that disk lined well with rotor.
Bye
Bye
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
edit:
Thanks for the info. Has anyone any experience of rotors from these guys?
edit:
