symtoms of bad main relay...
Old May 28, 2007 | 10:37 AM
AK_CRX's Avatar
Default symtoms of bad main relay...
I just got my swap running last night (f23 running obd-1 poa ecu) engine was running at 1,100 rpm and shut off. went to turn the key off then back on and noticed I didn't hear the click from the main relay, and the fuel pump didn't power on. So I tried tapping the main relay, nothing. Then I tried swapping if for a known good one, nothing. So if the fuel pump isn't powering on and its not the main relay do you guys have any suggestions? BTW, all my main fuses are ok, haven't bothered to look at the ones under the dash though
Old May 28, 2007 | 01:15 PM
Crx Jimmy's Avatar
Default Re: symtoms of bad main relay... (AK_CRX)
look at the alt/sol fuse (under the dash lower left side, its 10 amp fuse between 2 15 amp fuses)if it blows no fuel pump or ignition. This is the most common one to blow when doing a swap. it might have blown for a reason double check to make sure the main power wire to the alternator is not shorted and there is no resistance in the line.
Old Jun 4, 2007 | 12:01 PM
AK_CRX's Avatar
Default Re: symtoms of bad main relay... (Crx Jimmy)
That was exactly the problem, friggen dejavu, I know I've been here before. Anyways thanks man, good troubleshooting
Old Jun 4, 2007 | 01:39 PM
dem0nk1d's Avatar
i usually pop the cap off the relay, heat up the solder points, and add a little more solder... 9/10 times fixed for good.
Old Jun 4, 2007 | 03:40 PM
Crx Jimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK_CRX &raquo;</TD></TR><TR><TD CLASS="quote">That was exactly the problem, friggen dejavu, I know I've been here before. Anyways thanks man, good troubleshooting</TD></TR></TABLE>
no problem
BTaylor
May 29, 2022 03:35 AM
Jcgbeasttube
Honda Civic (2006 - 2015)
Mar 19, 2018 10:07 PM
tfeagley
Feb 8, 2014 03:34 PM
shwanC
15
Dec 4, 2013 12:31 PM
Blown90hatcH
Aug 5, 2003 09:25 AM
