Broke 2 axles
Old Jun 3, 2002 | 06:30 AM
hybrid901's Avatar
Default Broke 2 axles
I went to the track yesterday and on my second run I broke both axles right on the launch. As soon as I dumped the clutch I broke both sides right at the splindes, the car didn't even move an inch. I'm having crazy axle problems has anyone else had this happen before? This is the first time I have broke an axle there I normally do it at the inner boot.
Old Jun 3, 2002 | 06:44 AM
.nate's Avatar
Default Re: Broke 2 axles (hybrid901)
Hope you made it hone yesterday in decent time
Old Jun 3, 2002 | 06:46 AM
rtype11's Avatar
are you using the right axles, yours might be to short with your engine swap and splines are not fully seated in diff? just a thought as it is hard to break both unless you have a drag spool.
Old Jun 3, 2002 | 07:01 AM
hybrid901's Avatar
Default Re: Broke 2 axles (rtype11)
Both axles were factory rebuilds so maybe they arn't as strong. I think I have a bad wheel bearing that I'm gonna change do you think that would cause any of my problems? I measured both axles before I installed before I installed them this time and they were right on according to the drive shaft shop.
Old Jun 3, 2002 | 07:18 AM
DSF's Avatar
DSF
Although, I have never confirmed this on my own. I have heard numerous reports that your "standard" factory rebuild is NOT as strong as OEM. So, maybe there lies your problem. Don't quote me on it, though
Old Jun 3, 2002 | 10:33 AM
SiRkid's Avatar
Default Re: Broke 2 axles (DSF)
well judgin by your times your probably making big power.... and stock axles wont hold up.specially if you DROP your clutch.
Old Jun 3, 2002 | 11:08 AM
hybrid901's Avatar
Default Re: Broke 2 axles (SiRkid)
Who has the best axles for the money for 350whp?
Old Jun 3, 2002 | 11:42 AM
b18bturbo's Avatar
best axles for the money right now are the DSS axles.
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
lx93cb7
Jun 18, 2009 03:23 AM
_ek9_Chri$_
Dec 9, 2008 08:33 PM
cd5_2NR
Feb 24, 2005 11:54 PM
austrian type-R
Aug 29, 2002 02:56 PM
