Why is my tach dead?
Old May 28, 2007 | 07:55 AM
regal1975's Avatar
Default Why is my tach dead?
I had my car down for a suspension rebuild for a couple of months and now my tach doesnt work... where do i start troubleshooting this? 89 crx dx btw... has a d15bvtec swap as well..
Thanks
Old May 28, 2007 | 09:17 AM
VegaS10's Avatar
Make sure the cable is still inside the vss on top of the transmission.
Old May 28, 2007 | 01:28 PM
Crx Jimmy's Avatar
Default Re: (VegaS10)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegaS10 &raquo;</TD></TR><TR><TD CLASS="quote">Make sure the cable is still inside the vss on top of the transmission.</TD></TR></TABLE>
what does that have to do with the tach? he said tach not speedo you would be getting a cel if the ecu was not seeing the tach signal, so a wire must be broken somewhere
Old May 29, 2007 | 03:57 AM
Cory man's Avatar
Default Re: (Crx Jimmy)
IIRC its the blue wire at the distributor harness. Make sure its not cut or disconnected.
Old May 29, 2007 | 06:05 AM
regal1975's Avatar
wierd.. I havent seen any other termpro people on this forum before.. though i havent been on TP in a while...
I checked the cable and it was out, but that was killing my speedo.. got that back, but still no tach.. Ill see if I can trace a blue wire, though my electrical system is oddball as hell..
Civicboy
Oct 9, 2008 07:55 PM
Brain3208
Jan 18, 2006 11:58 AM
jedubz
10
Apr 12, 2004 04:59 AM
ZCcivic91
Oct 7, 2003 09:58 PM
USDM 4G VTEC
Jul 17, 2002 09:01 PM
