FS: Exedy Clutch b-series (small spline, stage 1), S1 vtec tranny, b-16 flywheel
Swapped my gearbox for another. For sale is the old stuff.
Used Stage 1 Exedy Clutch -- for older b-series gearboxes. Small spline. $100.
See pix. Plenty of life.
Cable S1 (VTEC ratios) from my JDM B16 swap. Missing clutch lever arm. Slight 3rd gear grind only at high RPM shift when cornering. $300.
Flywheel (included if you buy both above) $20 otherwise.
josemig007
Dec 11, 2011 11:10 AM
Junkyard2000
Aug 27, 2007 01:13 PM
1slowcrx
Jan 21, 2007 06:37 AM
