Putting a B18C1 Engine Into An EG And Dont Know How To Put In The P/S
Old May 27, 2007 | 11:48 PM
driftwithme's Avatar
Default Putting a B18C1 Engine Into An EG And Dont Know How To Put In The P/S
Hi I don't really have A EG yet but im curious bout it. well anyways i see a person that is selling an eg and dropped an b18c1 engine inside but the problem is that it does not have power steering in the car. i wonder if that is possible in the eg and what kind of parts i would need to have power steering. If itz easy i prolly would get an eg if not i prolly going straight up integra. but iono yet. please help this honda lover. thanx for reading.
Old May 28, 2007 | 12:58 AM
the stock cx's Avatar
Default Re: Putting a B18C1 Engine Into An EG And Dont Know How To Put In The P/S (driftwithme)
depending on the type of model the EG is, some models dont have p/s if it doesnt then your best bet is to leave it as is. you would have to change the rack to a p/s rack and buy a p/s line and pump. if it does have p/s you should find a b series p/s line from del sol vtec, 94-00 integra. hope that helps
Old May 28, 2007 | 12:53 PM
Default Re: Putting a B18C1 Engine Into An EG And Dont Know How To Put In The P/S (thehondaguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehondaguy &raquo;</TD></TR><TR><TD CLASS="quote">depending on the type of model the EG is, some models dont have p/s if it doesnt then your best bet is to leave it as is. you would have to change the rack to a p/s rack and buy a p/s line and pump. if it does have p/s you should find a b series p/s line from del sol vtec, 94-00 integra. hope that helps </TD></TR></TABLE>
yea that helps, i trying to go for a EG Si, btw how come i need to get the p/s line from a del son vtec instead of just having the 94-00 integra line?
Old May 28, 2007 | 01:00 PM
JKov240's Avatar
You can't tell the difference between an EG with powersteering and w/o powersteering unless you're at a dead stop and are trying to turn
Old May 28, 2007 | 01:09 PM
both p/s lines will work. but you want to try and get the p/s line closest to your chassis with a b series and that would be del sol vtec. if you cant find one try 94-97 integra which is the next closest, and then 98-00. if your buying it out the factory get the del vtec one its cheaper by 10 dollars and is the closest to your chassis. if you already have one from a integra that should work also if its a 94-97 i know theres a slight difference in part number between the integra after 98.
Old May 28, 2007 | 01:36 PM
ooh okay thanx honda guy
Old May 28, 2007 | 02:15 PM
k e v i n's Avatar
Default Re: (driftwithme)
why do you need power steering? you really cant tell the difference unless your not moving
JHipps
May 5, 2014 06:29 PM
crzymine03
475
May 16, 2013 09:15 AM
Civic-Kids
Apr 13, 2007 01:14 PM
LSEGHATCH
Oct 10, 2005 02:45 PM
JapJunkie
Dec 16, 2003 08:32 PM
