91 ls with obd1 gsr swap
Old May 27, 2007 | 10:48 PM
highflyinhonda's Avatar
Default 91 ls with obd1 gsr swap
just picked up a 91 ls with a blown motor for 250. it just so happens that i have had a gsr motor just hanging out in my garage for about 8 months. well i started this swap and now im in some trouble. i have an obd0 b16 ecu and dizzy so i could make the motor obd0.
1: cant find a fuel rail to fit need a p72 but every one that i have tried wont work.
2: p/s bracket for head wont fit, apprently it didnt have the p72 bracket
3: throttle cable, i have no clue what to do about this.
Old Jun 4, 2007 | 07:04 PM
DAmnquickDA's Avatar
Default Re: 91 ls with obd1 gsr swap (highflyinhonda)
im assuming you have a DA? use your existing throttle cable. im doing a B18C swap in my 90 LS and thats what im doing. as far as wiring issues im using my obd0 harness with a few 0bd1 clips from gsr harness. i recomend using the gsr dizzy and ecu but everyone does there own thing. lose the AC unless u live in arizona or something. im ditchin AC and PS. i dont understand if your p72 brcket wont fit or if you dont have a p72 bracket at all??? if you need a p72 bracket ill sell u mine. make offer if interested
Old Jun 4, 2007 | 07:35 PM
Default Re: 91 ls with obd1 gsr swap (DAmnquickDA)
ok im a dumbass... im was just workin on my car and realized the throttle body is made for a RHD car thus the cable bracket is backward. my friend said to use a USDM TB. but again... i dont know for sure so ill keep my mouth shut. so... sorry for any misinformation
Old Jun 5, 2007 | 05:36 PM
b18c1ej8's Avatar
well the whole problem is that ur trying to use an ecu thats for obd1,2 you should try a chipped pr3, i had a 91 teg with a 00 gsr converted to obd0 and thats what i ran and it ran great
ivan93egreppin210
Jul 17, 2011 02:35 PM
DA STRIKER
Mar 2, 2011 08:48 PM
da9love
Jan 17, 2011 06:42 AM
boost fed ls
Jan 14, 2006 06:15 AM
rcnacura
Dec 19, 2002 02:30 PM
