Suspension & Brakes Theory, alignment, spring rates....
help, skunk 2 coilovers!
Old May 27, 2007 | 07:19 PM
PinoyxEJ6's Avatar
Default help, skunk 2 coilovers!
i got a 97 civic dx, and i adjusted only 3 of my coilovers so that my car can be dropped alittle bit. But my back right left suspension wont seem to drop. I mean the first spinner on the top that holds the springs seems to be jammed. I got the bottom spinner moving freely, but the top one seems to just stick. I even tried wd-40 and gripping the coilovers so that i can move the top spinner but nothing seems to work. Can someone help? or any suggestions? Thanks.
Old May 27, 2007 | 07:53 PM
kleen98accord's Avatar
Default Re: help, skunk 2 coilovers! (PinoyxEJ6)
try to contact skunk 2 and tell them about your problem. they should give you some advice.
Old May 27, 2007 | 09:49 PM
8krdline's Avatar
do you have the keys to move the perches? if not u can use a screwdriver to put in the indention and hit it softly with a hammer.
Old May 28, 2007 | 11:47 AM
PinoyxEJ6's Avatar
Default Re: help, skunk 2 coilovers! (8krdline)
yeah, i used the key to move the perches thingy, but it moves the whole coilover thingy that its on.
Old May 28, 2007 | 09:36 PM
red ej's Avatar
try moving it up first then down, and repeating it, or try the screwdriver and hammer thing.
Old May 30, 2007 | 09:28 AM
FalkenSiR's Avatar
just hit it hard you *****
Old May 30, 2007 | 06:03 PM
PinoyxEJ6's Avatar
Default Re: (FalkenSiR)
dont be a dick falkenSir! But when i tried turning the perches, the perches also moves the threaded aluminum sleeves too. And i tried gripping the sleeves, but when i do get a good grip and turn the perches it makes a Bad Squeeky sound.. Like running your hands down a chalkboard. And i know i am turning the perches the correct way too, because i have done alot of coilovers in my life.. Any one know my problem now? thanks
Old May 30, 2007 | 06:20 PM
8krdline's Avatar
Default Re: (PinoyxEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyxEJ6 &raquo;</TD></TR><TR><TD CLASS="quote">but when i do get a good grip and turn the perches it makes a Bad Squeeky sound.. Like running your hands down a chalkboard. </TD></TR></TABLE>
When I had just sleeve coilovers mine made a similar sound. It's just built up dirt in the threads. If you cant get the perches to turn in the worst case you can pull the strut out and put some thicker o rings on so the coilover doesnt spin when loosing the perches. If there is a good bit of dirt on them though you made need to hit them pretty good.
Old May 30, 2007 | 06:56 PM
PinoyxEJ6's Avatar
Default Re: (8krdline)
Thanks, 8krdline.. imma try that tommor. IF i run into anything else i let you know about it.
Joshb152
Suspension & Brakes
Apr 1, 2015 05:13 PM
gnxpro24
Suspension & Brakes
Sep 14, 2014 09:40 PM
ptown909
Nov 19, 2008 12:39 PM
dc2long
Apr 23, 2007 11:47 PM
