O2 Sensor Wiring: Which wires matchup? (GSR)
Old May 27, 2007 | 06:55 PM
superfuji57's Avatar
Default O2 Sensor Wiring: Which wires matchup? (GSR)
On my engine harness side I have Yellow/Black, Orange/Black, Green/Black, and Yellow/Red wires. Sensor side has the usual Black, Black, Green, and White.
Right now, I have it:
Y/Blk -- Blk
O/Blk -- Blk
Grn/Blk -- Grn
Y/Red -- White
Is this right? Every now and then I'll get CEL code 1. Also, my idle fluctuates often between 100 and 1100 RPMs.
TIA
Old May 27, 2007 | 06:56 PM
Oh, yeah. I should mention I have Hondata and that the reason I'm asking about the wires matching up is because they ripped out of the plug when I took out the motor a while back.
Old May 28, 2007 | 05:41 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: O2 Sensor Wiring: Which wires matchup? (superfuji57)
yeah thats right, if it runs not quite right swap the black wires around
Old May 29, 2007 | 09:42 AM
Relic1's Avatar
which year GSR do you have? those engine harness wire colors don't really match up to the wire colors of the honda's I've seen. (95% of the time O2 signal is white)
Old May 29, 2007 | 06:48 PM
It's a '95. Though, I haven't tried switching the grounds yet...
Old May 30, 2007 | 08:33 AM
Relic1's Avatar
according to the Helm manual these should be your O2 colors.
yellow/black - + heater
orange/black - - heater
white/red - + O2 signal
green/blue - - O2 signal
which should match up to the O2 sensor like this...
yellow/black - black
orange/black - black
white/red - white
green/blue - green
the idle problem may be related and it may not.
Which ECU are you using? Have you checked for vacuum leaks?
OoAoO
Jun 27, 2011 10:09 PM
superfuji57
May 27, 2007 02:56 PM
accrdpusha
Sep 16, 2005 04:09 AM
pyrojeff
May 17, 2004 06:30 PM
