Axle comparison - STD vs. Si.
Does anyone know whether or not these axles are different/compatible? I have a standard hatch that comes with a 4 speed manual tranny, and a zc swap. I'd like to go Si 5 speed, but was a unsure about the axle/hub compatibility. I asked Jason from the zc for dummy's website, and he said they are the same, and i'm just looking for second opinions. Thanks!
..I believe that the inner's are the same, but the outer's are different... so if you use the si tranny, you 'should' be able to keep those axles...
inner joints are the same. You can use the STD/HF axles with Si/DX/HF/STD trannys.
But the puny brakes SUCK!!!!!!!
I just got my 91 STD HB with DX driveline on the road last week.
