Turbo Website?
what would u guys prefer..swap h22 or turbo charge..which one of these two will be more reliable in the long run. And does anybody knows some website where you can buy turbo kit or a h22 swap for a 95 accord?
This has been discussed many times, check out the search feature.
I would suggest an H22 swap AND a turbo if you can afford it
If I had the money, I would turbo, cause I love the sound.
I would turbo for the power !!!! Also its cheaper than the H22 swap , plus . F-series motors love boost. Cant boost h22 unless its sleeved. Not a reliable motor once it sees a turbo , But there great motors that can take a beaten . Also n/a h22's can get up there in hp.
what do you mean cheaper in turbo?..because looking in a H22 engine (no tranny), the cost of it is only $1000..and that I can just use the f22 tranny, although there might be a longer gear ratio. anyway, I've found a turbo for 1800 over at the TAS page, but anybody knows if that turbo can boost my HP to 250 and can also be a daily driven car.
I forgot to mention , that if you can fab some of the parts as the turbo manifold and down pipe. You can build your own kit for about 1000-1200. Youll still need engine managment.
If you went the H22 route. Will you be installing it or paying someone to preform the work ?
