Front Fenders
Old May 27, 2007 | 05:30 PM
honda94accord's Avatar
Default Front Fenders
Does anyone have a description or a picture on how to get the front fenders off of a 94 ex sedan? Im wanting to put jdm fender turn signals in but i need to kno where all the bolts are that hold the fender on and how hard it will be.
Old May 27, 2007 | 06:11 PM
momstaxi's Avatar
Default Re: Front Fenders (honda94accord)
you will need to remove the front bumper, the side skirt to access all the fender bolts, you will also need to remove the fender liner or detach it from the body or fender to remove
Old May 27, 2007 | 08:04 PM
kleen98accord's Avatar
you don't have to take off your fender. when i installed mine i didn't have to take it off. reasoing being is because i took off the splash guards.
Old May 29, 2007 | 03:39 PM
Default Re: Front Fenders (randomvtec)
But how did u run the wires to get them to work if you didnt remove the fender? And what did u wire them to to get them to work?
Old May 29, 2007 | 04:28 PM
Loco-B's Avatar
there are plenty of options on where to wire them.....
i know if you want them to stay off, and blink when the turn signal is engaged you just run your wires from the bumper turn signals. I know there have been a few threads written up on this. I'd say try a search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randomvtec &raquo;</TD></TR><TR><TD CLASS="quote">you don't have to take off your fender. when i installed mine i didn't have to take it off. reasoing being is because i took off the splash guards. </TD></TR></TABLE>
thats not a very good reason, in fact it doesnt even make sense......besides if you want to do this project properly without denting or bending your fenders your going to want to take them off.
Old May 29, 2007 | 04:50 PM
TheMuffinMan's Avatar
He knows where you live!
&lt;-- installed his sidemarkers with fenders on and no dents
dremel cut off wheel + high speeds = cuts through like butta'
I took out the outide pins of the fender liner and zip tied the side marker wires along with the other wires already in there (to headlights, etc) and then clipped it all back together.
I took out the turn signals and then soldered the connections to that. works fine and looks good
Old May 29, 2007 | 04:55 PM
Loco-B's Avatar
Default Re: (TheMuffinMan)
lol......i did mine with the fender on....
it didnt turn out so hot. I ended up buying passwordjdm fenders. I guess it all depends on how handy / much of a perfectionist you are.....
hey muffin did you ever find a way to seal yours with that gasket you were talking about?
Old May 29, 2007 | 04:56 PM
haha no, I played with it for quite a bit with no luck
I got some foam craft paper stuff and tried that, but it was too stretchy and didn't seal anything, I'm thinking caulk or something would be the only permanent solution right now I just have touch up paint covering the metal
trevorjohn88ef
Mar 30, 2008 10:10 PM
gsxr750jah
Honda S2000
Jun 11, 2006 10:28 PM
fstgsr
Jun 14, 2005 09:23 AM
grlstockb18c1
Jun 11, 2004 01:05 PM
BRICKHEAD
Nov 9, 2002 08:31 PM
