92 accord moving problems
Old May 27, 2007 | 05:07 PM
monster accord's Avatar
Default 92 accord moving problems
hi there im new to this so sorry if i aint good any who i just put another 5sp tranny in my car
got every thing working wright with a stage 1 clutch and flywheel they work great, any way i took it for a test drive yesterday every thing was great all went wonderfull and then i get back to the house and stop in the driveway to check all is still good i go to park the car and it wont move iv checked the breaks to make sure they arnt locked up there fine and i put the car on jackstands and the wheels turn fine through all gears cant figure it out im gonna pull the axles tommow and see if i did somfin rong any feed back would be great im really frustrated with it all thanks
Old May 27, 2007 | 05:14 PM
JDM_DC4_Fanatic's Avatar
Default Re: 92 accord moving problems (monster accord)
hows the clutch feel? Did you make sure that the clutch was bleed when you change the slave cylinder? what do you mean by "it doest move" do the gears grind? is the clutch slipping? we need more detail about whats going on other then "It doesnt move"
Old May 27, 2007 | 05:22 PM
Default Re: 92 accord moving problems (JDM_DC4_Fanatic)
the clutch is brand new by not moving i meen that it feels like your taking of in 4th gear and the clutch starts smoking but when you put it in reverse it moves great i did get a short through shifter but that is working fine cuz i drove it for a good 2 miles through all the gears but at the house you move a little but then it wants to stall out
Old May 27, 2007 | 05:23 PM
tranny is new and the slave was bled very good
Old May 27, 2007 | 07:46 PM
tortillahuntercb7's Avatar
ok so does you clutch engage(how ever its spelled)?does the clutch pedal drop to the floor ?
does the car go in gear while the engine is on ?
HondaNation301
Transmission & Drivetrain
Sep 10, 2014 05:07 PM
Ajsbored
Mar 12, 2014 08:37 AM
2dooraccord
Nov 24, 2008 04:47 AM
clean3two3
Sep 15, 2007 11:51 PM
blue_eyed_taoist
Jan 3, 2006 08:46 AM
