Suspension & Brakes Theory, alignment, spring rates....
10/9 sprign rate
Old May 27, 2007 | 03:37 PM
kleen98accord's Avatar
Default 10/9 spring rate
would a 10/9 spring rate with koni spss valved shocks be too rough for a daily driver?
driving on streets and the freeway?
what would be a better spring rate for daily driving and the once in awhile aggressive street driving?
ps. im leaning towards a liitle more performance than comfort.
Old May 27, 2007 | 04:42 PM
chrisw85's Avatar
10kg/mm is about 560 lb/in. 9kg/mm is about 504 lb/in.
That shouldn't be too bad if you're going to use the spss3 valving, but it will be very noticeably stiffer than stock. For track days, just swap the springs front to rear to lessen the understeer. Get the same length springs and it should be pretty easy.
Old May 27, 2007 | 07:51 PM
Default Re: (chrisw85)
thanks. i used to track my car at streets of willow. that was pretty fun. thanks tho. right now, i dont' think immma track much. more aggressive street driving. haha
redline32
May 20, 2009 01:56 PM
Rostr02
Suspension & Brakes
34
Jan 17, 2005 08:11 PM
xjohnx
Oct 26, 2002 03:07 PM
Muckman
19
Aug 9, 2002 12:00 PM
Flux
Jun 26, 2002 02:26 PM
