VTEC HITS?
Hey does anyone know when Vtec kicks in a D15B!!! Prob. is that i think my chipped p28 has B16 maps on it not really sure
Anyways how do you know when Vtec kicks in!? Would a bad ground not allow Vtec to kick in and it will give you a CEL? Im asking cuz i dont know what to look for when it comes to Vtec kicking in and i think maybe my ground is bad but have no CEL!! Any input is greatly app.
my d15b kicks in at around 5200 my ecu isn't chipped though and it's not loud enough on d series to hear it kick in it usually clicks but you'll feel it when it does hit.
as for the ground i don't think so it should kick in as long as the motor is warmed up and there is enough oil
edit: there are other reasons why it wouldn't but those are the basic ones that people will tell you to check
A bad ground would probably not allow the engine to run, let alone hit VTEC. What's your oil pressure like? I know it may sound elementary, but the ECU won't allow VTEC to engage if it doesn't reach proper operating temperature. Do you have cooling problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">supposed to be around 5000rpm. But it's not loud enough on those motors to hear for sure.</TD></TR></TABLE> Yeah is that on the D15B or B16? I think my ecu has B16 maps from what that other guy who chipped it said!!! Is it B16 or D15?? Does it matter!!!? I have Autotechnic revolution intake,OBX header.2.5 catback,msd external coil kit, so im guessing maybe i should be able to hear it? Does anyone know if a bad ground on OIL Press. Sensor can cause a CEL!!! I mean the one that goes with Vtec Sol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote"> Yeah is that on the D15B or B16? I think my ecu has B16 maps from what that other guy who chipped it said!!! Is it B16 or D15?? Does it matter!!!? I have Autotechnic revolution intake,OBX header.2.5 catback,msd external coil kit, so im guessing maybe i should be able to hear it? Does anyone know if a bad ground on OIL Press. Sensor can cause a CEL!!! I mean the one that goes with Vtec Sol.</TD></TR></TABLE>
you will hear it on a b series but not a d series, d series kick in anywhere from 5k-5500
b16 is at 5800 i believe but i'm not positive on that one maybe 5600
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">A bad ground would probably not allow the engine to run, let alone hit VTEC. What's your oil pressure like? I know it may sound elementary, but the ECU won't allow VTEC to engage if it doesn't reach proper operating temperature. Do you have cooling problems?</TD></TR></TABLE>What i mean is i dont even know how it feels when it kicks in i just did the swap and i just now replaced the ecu with a p28! When it comes to ground i mean the ground from the oil press. sen. since i did a swap i have to wire it my self!!!! My q is will that cause a CEL (bad ground on Oil Press. Sen.)
it kicks in at 5200 on p08 ecu that originally comes with that motor. By no means it will be loud enought to hear (especailly with 2.5" exhaust, since vtec is only on intake side). Bad ground on oil pressure switch will throw a CEL. If you got bad ground to the motor your motor will run like complete ****. There is no ground running to vtec solenoid it uses engine ground. There is a solenoid wire coming out of the ecu that's running to it. Usually when vtec won't kick in car will feel like **** anywhere past 5500rpm. I used to rev a d15b to 8,000 rpm back in the day, couple times ended up at 9000rpm just by not looking. That motor is really rev happy due to the stock cam that's in it so if I were you rev it 8,000rpm and if it feels like **** prolly vtec is not kicking in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">
b16 is at 5800 i believe but i'm not positive on that one maybe 5600</TD></TR></TABLE>
most d series from 5-5.5k
b16 5.2k
b18c1 4.5k
b18c5 5.5-6k
b16 5.2k
b18c1 4.5k
b18c5 5.5-6k
my friend's b16 is at 5800 not tuned... but i know alot more about sohc then dohc so take abk's advice on the b series stuff
and damn! i didn't know that the c1 was 4.5k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">my friend's b16 is at 5800 not tuned... but i know alot more about sohc then dohc so take abk's advice on the b series stuff
and damn! i didn't know that the c1 was 4.5k</TD></TR></TABLE>
what is it b16b?
yea c1 is pretty horrible, 4.5k vtec 6.5k secondaries. Change the intake matifold on c1 and run stock ecu your car will just drone out at 4.5k and not go anywhere until like 5.5-6k. It's pretty funny, really loud but not going anywhere.
what is it b16b?
Well thanks a lot guys you been really helpful ! Im going to take my car for a spin !!! By the way it does kind of pull really hard after 5000 rpm so i guess it is kicking in !!!! Oh well im going to start making the preperations for my Greddy turbo kit!!!! I need to drill a hole on pan for return line!!! Thanx anyways its really APPRECIATED!!! Oh yeah by the way hey 94c1v1c take me off your sig!!! And yes i do have my turbo kit ready to be installed ill let you know how the PSSSHHHH Sounds!!! LMAO Laterz Dudez
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex »</TD></TR><TR><TD CLASS="quote">haha ya it's gettin old i'll take it off</TD></TR></TABLE> COOL THANX
