Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Adhesive for HFP front lip
Old May 27, 2007 | 11:53 AM
NoPainNoGain's Avatar
Default Adhesive for HFP front lip
I wanted to install the HFP front lip and possibly the rest of the kit later on but I wanted to know if the adhesive provided with the lip would hold well. Should I buy something better or will it due. Any insight would be great-thanks
Old May 27, 2007 | 12:03 PM
WILD_WILL's Avatar
Default Re: Adhesive for HFP front lip (NoPainNoGain)
If put on correctly the oem adhesive will hold just fine if it ever starts to come loose just buy some stronger 3M tape and you will be fine
Old May 27, 2007 | 06:21 PM
ucd_4_life's Avatar
You gotta really clean the contact areas, and let it sit for one day out in the sun before cleaning with water.
Old May 27, 2007 | 06:26 PM
Default Re: Adhesive for HFP front lip (ucd_4_life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ucd_4_life &raquo;</TD></TR><TR><TD CLASS="quote">You gotta really clean the contact areas, and let it sit for one day out in the sun before cleaning with water.</TD></TR></TABLE>
Why in the sun curiously?
Old May 28, 2007 | 03:13 PM
will_rex's Avatar
All the sun does is heat the adhesive and make it tackier. I would just use a heat gun or hair dryer and heat up the adhesive prior to installation. This will help it adhear to the car.
Old May 28, 2007 | 03:38 PM
hondamanforlife's Avatar
Default Re: (ObnoxiousGuy)
mine has held up fine for the past 2 weeks and seemed to be a tight fit anyway.
styol
Feb 25, 2007 12:03 AM
triple999
Oct 29, 2006 05:10 PM
simplegreenmachine
Aug 2, 2006 08:27 PM
phan
May 28, 2004 05:32 PM
N1NjA TuRtLE
Jan 1, 2004 09:08 AM
