There's fuel but NO spark!
Old May 27, 2007 | 10:46 AM
powerneedy's Avatar
Default There's fuel but NO spark!
alright i have a b16a2 in my eg and i just ompleted the swap. the deal is a got it going drive it a couple times and was throwing a o2 sensor cel so i wired that in correctly and drove it for about 5 miles and then took it home so i could clean everything up. well no i wont start! its got fuel bu no spark. i have changed the coil, the igniter, cap, rotor, spark plug wires, plugs, i am outta ideas. i have even checked my wiring even though i didnt touch anything except for vtec and o2...
HELP
Old May 27, 2007 | 10:48 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: There's fuel but NO spark! (powerneedy)
are you getting power to the dizzy?
Old May 27, 2007 | 10:56 AM
powerneedy's Avatar
which wire do i need to check ?
Old May 27, 2007 | 11:05 AM
Throwdown's Avatar
Default Re: (powerneedy)
i believe its the black wire with yellow stripes ....your dizzy may have just taken a **** bro
Old May 27, 2007 | 01:25 PM
h22-hatch's Avatar
Default Re: (Throwdown)
check your grounds, plus you put a obd2 motor in a obd1 car, definitely check the dizzy it will throw it off big time thats what happened to me with my h swap in my eg
Old May 27, 2007 | 11:57 PM
powerneedy's Avatar
no man im a obd1 motor in a obd1 chassis... sir b16a2
and throwdown thats what im thinkin...
Old May 28, 2007 | 12:04 AM
Throwdown's Avatar
thats were i would go if you getting power to it one of the three sensors maybe went bad or something else internally..honda dizzys=****
Old May 28, 2007 | 12:16 AM
powerneedy's Avatar
also when it would kinda of start the tach would jump all over...?
Old May 28, 2007 | 12:23 AM
cliniCrx's Avatar
definetly check your grounds. i had the problem of the tach jumping in my ek, it ended up being the engine and tranny were not grounded. check both of those grounds. also, your dizzy may be shot as well if those grounds were not there, it could have burnt out.
Old Jun 4, 2007 | 08:35 AM
powerneedy's Avatar
well i have put the dizzy on another car and it worked and i have also tried another ecu and no luck! i have know clue why its doing this its getting power to the dizzy for some reason its not sparking!
Old Jun 4, 2007 | 01:54 PM
JG90CRX-Si's Avatar
Bump, cause I'm in the same ****!!!
I've got power going to the dizzy, new igniter, extra ignition coil (original is gone), new - spark plugs, wires, rotor cap and no spark? I just blew another fuse so don't know what's up?
Subscribed and Good Luck!
JG
Old Jun 5, 2007 | 01:10 PM
powerneedy's Avatar
haha this is stupid i have never had such a problem and im not blowing fuses!
Old Jun 6, 2007 | 01:47 PM
JG90CRX-Si's Avatar
Bump, I may pick up another dizzy today to see if it's the problem.
JG
Old Jun 6, 2007 | 05:25 PM
powerneedy's Avatar
alright i picked up a new harness and guess what i got spark! took the twenty minutes and put the new one it! and it runs. im so lost how my car ran and then didnt... oh well
turbogrs
15
Oct 13, 2010 09:42 PM
DelSlowmo
Mar 16, 2010 08:42 PM
tree fingers
Aug 4, 2009 11:58 AM
iheartmyctr
Feb 26, 2009 04:36 PM
Dyce
Aug 19, 2007 08:40 AM
