crx hf convertion to crx si
Old Jun 2, 2002 | 10:29 PM
jrcrx's Avatar
Default crx hf convertion to crx si
I'm trying to do a swap for a friend, I came into a little dilemma. Can you use the hf engine wiring harness on the si engine or use the si wires to connect to the hf. I thought that since they are both multi port that it would not matter which harness to use. I thought that I would be easier to use the hf wire harness since the car it self is an hf and the hf has more sensors than the si, so I heard! If I did use the hf engine harness do I have to modify the wires in order for the car to work properly or even start and if so which wires to modify. In the other case, If I was to use the si wires what wires need to be modified. Just trying to help a friend because her old hf engine block is crack, since I had a si engine laying around I thought it would be nice to give to her as a gift. If anybody has any info email at jrcrx76@ yahoo.com, it would be a great help thanks!!!!!
Old Jun 2, 2002 | 10:30 PM
Urban Business
Guest
Posts: n/a
Default Re: crx hf convertion to crx si (jrcrx)
hf harness will work fine. its wired the same as the si
peiku
Feb 21, 2006 03:10 PM
89 pos
21
Mar 9, 2005 09:47 PM
KevronsEG
Nov 20, 2003 07:57 AM
I Gotta Question
Feb 11, 2003 10:18 AM
91HATCH
23
Oct 15, 2002 05:03 PM
