what is the best lower arm bar tie bar
I know the ASR kit is designed to prevent subframe tear out but I'm curious if it does away with the need for a tie bar.
It looks beefy enough that I'd imagine you won't need a tie bar any longer. I guess that's the advantage over the BSQ and Beaks kits? Plus, will the threads of the bolt be long enough for a tie bar PLUS the ASR kit anyway?
