why is my steering wheel to the left, when I'm going straight?????
When I drive straight, my steering wheel is about a 1/4 turn to the left. If I turn my wheel center I start to drift over to the right. If I let go of my steering wheel My car pulls hard to the right.
What could be causing this?
hahah. i have the same exact question. i don't know man. got used to it. sometimes its the amount of air in your tires. i tried the alignment. but it doesn't work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randomvtec »</TD></TR><TR><TD CLASS="quote">hahah. i have the same exact question. i don't know man. got used to it. sometimes its the amount of air in your tires. i tried the alignment. but it doesn't work. </TD></TR></TABLE>
The thing with this is, you can just "get used to it" but the steering wheel being off center like that means your toe end of the alignment is off. And if the OPs car is veering off to one side when he isn't hold the wheel, that means his alignment is bad. If he just lets it go, he will eat up tires faster and will eventually cost more money down the road to keep replacing the tires that are wearing unevenenly.
OP-->Go to a shop and get an alignment. Make sure it's a reputable shop and see if they can give you the results at the end of the adjustments they had to made.
Dezso3
Honda Civic (2006 - 2015)
Jul 23, 2015 01:19 PM
