Radiator cap pressure?
Old May 26, 2007 | 05:08 PM
g2b2's Avatar
Default Radiator cap pressure?
I need to buy a new radiator cap for my 91 hatch, the one that is on it is a Stant so it isn't original and is good for 13 psi, is that what the stock cap is good for or is it supposed to be 16 psi? Thanks.
Old May 26, 2007 | 08:17 PM
Crx Jimmy's Avatar
Default Re: Radiator cap pressure? (g2b2)
that is stock pressure(13psi) I found another stant cap that was 16 psi that I use.
Old May 27, 2007 | 11:49 AM
g2b2's Avatar
Default Re: Radiator cap pressure? (Crx Jimmy)
now that your using a 16 psi do you notice any difference as far as the overflow tank and stuff? I'm probably gonna go to a 16 psi but I just want more opinions, my car doesn't over heat and never has so I dont think it would matter if i went to a 16 psi.
Old May 27, 2007 | 02:17 PM
cr-x-91's Avatar
just stay at 13 psi...thats what the cooling system was designed for...every one pound of psi makes the boiling point go up 3 degrees,dont go up on psi...hoses can blow.
Old May 27, 2007 | 05:46 PM
Crx Jimmy's Avatar
Default Re: (cr-x-91)
Im sure a 16 psi cap is ok, I havent had any problems running it in 5 years. Also if you buy an expensive spoon or mugen cap all it is is a 16 psi cap.
ES2
Honda Civic (2001 - 2005)
Jun 12, 2007 03:29 AM
redzcstandardhatch
Jan 19, 2006 08:03 AM
Sprockets
Oct 19, 2005 07:53 PM
SystemGSR
Jun 21, 2001 06:50 PM
