whistling noise inside accord 2000 v6 ex coupe please advice =[
Old May 26, 2007 | 01:09 PM
vukbui1987's Avatar
Default whistling noise inside accord 2000 v6 ex coupe please advice =[
about a month ago, my 2000 v6 coupe accord start having a whistling sound that can be heard inside the car, i went outside to get it check and the mechanic told me that it was the alternator making that sound, my question is that if the alternator was makin the sound then wouldn't i hear it from outside also? the other problem i was lookin at is that i saw a lot of people having EGR valve problem in this model so how much would it be to replace an EGR valve and how do u know if there is something wrong with it.
thank you very much
Old May 26, 2007 | 01:16 PM
skingfreak's Avatar
Default Re: whistling noise inside accord 2000 v6 ex coupe please advice =[ (vukbui1987)
no sure about the whistling. But as far as the EGR goes, if your not throwing a code your fine for the moment, you will just need to have it cleaned if/when you do throw a code, but to get it replaced at a mom/pop shop would probably be around 200-300.
THe main concern in this modle is the trans tho, they suck...
dahd00d
Apr 28, 2015 05:00 PM
vukbui1987
May 26, 2007 07:04 PM
tt
Jun 30, 2006 05:40 AM
V6CpeGirlie
Jan 28, 2002 12:15 PM
