Need a transmission specialist for my transmission question.
you may need to re seal the casing of your transmission also you may want to check your axels to make sure they are all the way in and that the axel seals are not leaking fluid and its just running down the trans casing seem as far a a new seal for the casings i dont believe an actual seal or gasket is make you just have to use gasket maker. or blue glue as some people call it
looks like you nicked a axle seal very common if your not careful when removing the axles.
Modified by dtapia at 9:53 PM 5/28/2007
the reverse light switch might be leaking at the wire portion and if it is replace the reverse light switch. did you remove it when you did the clutch ?
Tampa94lsteg
Feb 18, 2009 06:12 AM
DeDonDeRosa
Sep 26, 2006 02:05 PM
