Tranny Swap ???? NEED HELP!
Old May 26, 2007 | 11:18 AM
prelude1911's Avatar
Default Tranny Swap ???? NEED HELP!
I have a 1997 Honda Prelude SH and I swap out the SH tranny and atts unit for a M2A4 tranny equipped with a KAAZ LSD. I already got the intermediate shaft and the drive axles all on. But when I connect the two shift linkage I can't shift in the cockpit. I was thinking maybe I need to swap out the linkage and use the older 92-96 Prelude linkage. Has anyone ever done this? or anyone know what the problem could be?
Old May 26, 2007 | 05:32 PM
come on anyone? I need this car back on the road. 300whp Prelude with a new Kaaz LSD!
Old May 26, 2007 | 07:46 PM
petern101's Avatar
Default Re: (prelude1911)
why older shift linkage?
try a base prelude's shift linkage first
Old May 26, 2007 | 11:50 PM
Default Re: (petern101)
the base prelude linkage is the same as the SH linkage. The m2a4 is off the same year prelude as the tranny.
Old May 27, 2007 | 08:41 AM
mgags7's Avatar
The linkage should work just fine.
Have you tried shifting it at the transmission yet, if not try that and get back to us.
Old May 27, 2007 | 08:48 AM
THC07's Avatar
Default Re: Tranny Swap ???? NEED HELP! (prelude1911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1911 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1997 Honda Prelude SH and I swap out the SH tranny and atts unit for a M2A4 tranny equipped with a KAAZ LSD. I already got the intermediate shaft and the drive axles all on. But when I connect the two shift linkage I can't shift in the cockpit. I was thinking maybe I need to swap out the linkage and use the older 92-96 Prelude linkage. Has anyone ever done this? or anyone know what the problem could be? </TD></TR></TABLE>
what do you mean by saying you cant shift. whats the shifter doing or not doing?
is it not moving? not moving enough?
Old May 28, 2007 | 12:56 PM
Default Re: (mgags7)
It shifted into every gear fine when I do it by hand. But when I go inside the car and try to shift it into gear it doesn't wana go into any gears.
Old May 28, 2007 | 12:58 PM
Default Re: Tranny Swap ???? NEED HELP! (THC07)
it doesn't go into any gears. i can't even move it left or right when it is in neutral. it just feel all out of place.
Old May 29, 2007 | 08:09 AM
I need help! anyone know. I don't wana have to change the linkage and that **** still doesn't work.
dre2day
Northern California (Sales)
May 29, 2011 01:07 PM
JSR
Oct 7, 2004 12:15 PM
VtecDA9
Aug 4, 2003 06:33 AM
importneeds
Nov 15, 2002 11:22 PM
