Changing clutch - transmission stud bolt MUST be removed?
Old May 26, 2007 | 09:40 AM
arkosh.kovash's Avatar
* B A N N E D *
Default Changing clutch - transmission stud bolt MUST be removed?
I am changing my clutch for the first time and the service manual (section 13-9 step 31) says to remove transmission stud bolt #11--a few steps before dropping the tranny.
Is this really necessary? I already got the transmission mount and mount bracket out. But of course am having difficulty pulling the stud bolt. The more I look at it, if I already have the mount out, do I need to pull this one stud bolt for any other reason?
Old May 26, 2007 | 03:33 PM
spoonfedcrx's Avatar
it might aid in clearing the frame rail or radius rod when removing the trans from car. try to take the trans out without removing it. if its in the way take it out. if you dont have a stud removal tool just take two nuts and tighten them on the stud and take it out that way.
Old May 26, 2007 | 05:18 PM
MiKeAhOwSkI's Avatar
Default Re: Changing clutch - transmission stud bolt MUST be removed? (arkosh.kovash)
let me tell you firsthand...if you can get that stud out it will help a lot! it is a very tight fit trying to drop the trans out past the frame rail, that stud DOES get in the way...but mine wouldn't come off so I had a lot harder time getting the trans off.
Old May 29, 2007 | 03:49 PM
* B A N N E D *
Default Re: Changing clutch - transmission stud bolt MUST be removed? (MiKeAhOwSkI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiKeAhOwSkI &raquo;</TD></TR><TR><TD CLASS="quote">...but mine wouldn't come off so I had a lot harder time getting the trans off.</TD></TR></TABLE>
well, i learned that the hard way. it sucked *** wrestling the trans out. i went ahead and took the stud bolt out for the reinstall. also, i think i am going to go with a hoist from up top. i tried to manhandle it and get it into place but i'm puss and it kicked my ***.
thanks for the tips fellas
xpdude
Jun 26, 2009 01:49 PM
lmike6453
Jun 4, 2008 07:15 PM
Ltsmith05
27
Apr 6, 2006 11:24 AM
Ronin150
Nov 17, 2004 09:21 AM
ki11a8ee
Mar 12, 2004 05:51 PM
