94 Accourd turns over fast but dont start
Old May 26, 2007 | 04:36 AM
bruce2448's Avatar
Default 94 Accourd turns over fast but dont start
car was running great going down the road and stalled....it turns over fast but doesnt start?main relay switch is good...coil is new...timing belt is still intact...whats the problem?there is no fire what so ever....can any 1 tell me what i need to change?
Old May 26, 2007 | 05:55 AM
wildcat98's Avatar
Default Re: 94 Accourd turns over fast but dont start (bruce2448)
that sounds like you have no ignition..
check you distributer...
option 1
1. take out the number one plug wire
2. place a screwdriver in side the plug wire and rest it in the cam cover
Do the above with the ignition OFF !!!!!!
3. crank over the engine
4. check to see if it sparks on the cam cover
if not call i electrician
option 2
1. pull off the fuel return line off the fuel rail or regulator
2. crank the engine
3. look for fuel coming from the rail or regulator
if not your fuel pump is shot...
Old May 26, 2007 | 01:47 PM
hondaccord's Avatar
Default Re: 94 Accourd turns over fast but dont start (wildcat98)
its odd, do you mean that it is cranking faster then normal or just that it still seems fine. if it is faster then what it was before then i'd check the compression, just because the t-belt looks good doesn't mean it didn't jump a tooth or so. Also did it die, and then not start agian or did it just stop starting? have you check injection pulse?
turkdavid
Jan 25, 2010 07:28 AM
Turbo-Honda
Oct 5, 2004 09:25 PM
lke2drvgsr
Jan 3, 2004 03:27 PM
2ndGenREX
Dec 3, 2003 07:11 PM
bluedelsol
Feb 16, 2003 02:49 PM
