b18 swap
ok you guys i was plannin on the b16 swap but i found some mounts that let the 18 drop in...what all do i need be explicit as possible...a sight would be great to with instructions....thanks guys...you havent let me down yet
kyle...skunked out
89 civic hb si
black primer with white stripe down center
kyle...skunked out
89 civic hb si
Guest
Posts: n/a
hmm well if you found a kit that lets a b18 drop in it'll let the b16 drop in as well. 90-93 teg axles and intermediate shaft, adjustable shift linkage. y1 or similar trans sledge hammer, pull off dust shields in hubs, engine hoist/cherry picker, corresponding starter for the trans, alternator, timing belt, oil, tools, beer bong for trans fluid, a friend, stereo in the garage. if your car is black w/ a white stripe going down the middle i dont want you to swap the motor
[Modified by TorteX, 11:45 PM 6/2/2002]
Guest
Posts: n/a
rafimos (11:49 PM 6/2/2002): whats that comment about man...if your car is black w/ a white stripe going down the middle i dont want you to swap the motor
it means ditch the stripe before you swap a motor. i can kinda see an all primer car but an all primer car with a racing stripe is too much for me.
lmao grrrreat!!!!
by the way when useing the si wireing there are no changes needed to be made???
how about exhaust cam sensor?
its just plug and play right???
no changes what so ever???
thanks alot
-larry!
im with limo ditch the stripe
thanks alot
-larry!
rafimos (12:05 AM 6/3/2002): its not a racing stripe its a skunk stripe....get it right...jk man...its going to be painted that new lude blue before the swap. but thanks for the info man
np
<IMG NAME="icon" SRC="http://images.zeroforum.com/smile/emthup.gif" BORDER="0"> good luck w/ the swap
np
of course they disappeared the next morning when we sobered up
good times.
