MPFI SWAP QUESTION, and yes I already searched
Old May 25, 2007 | 09:43 PM
RedEfGoKart's Avatar
Default MPFI SWAP QUESTION, and yes I already searched
Ok i have searched and all I find is info on what to do if you have to convert/cut wires on your harness.
I have the whoole harness form an SI, and the P06 Ecu if I rember right.
All I need is the dizzy for the SI and the swap the harness and ecu right. this may sound stupid but i havent read of people doing it this way.
PLEASE let me know if you guys have any knowledge in this area
Old May 25, 2007 | 10:16 PM
B16acivicsedan91's Avatar
Default Re: MPFI SWAP QUESTION, and yes I already searched (RedEfGoKart)
I did a mpfi swap on my sedan and as far as i know you cant just use the si harness. You can send both to rywire for a swap or you can just add 2 injector wires and a resistor box possibly rewire your distributor if needed and 02 and vtec if your going b16
Old May 25, 2007 | 10:24 PM
Maybe you misunderstood, I have the whole set up for 4 injectors, the ecu and the whole engine harness from an SI
i will be putting it on My D15b2
I just need to know if there are other isssues or can i plug and play since i already have a complete harness
Old May 27, 2007 | 08:37 AM
EF_338's Avatar
no you can not just use the si harness, you would have to cut/convert your stock one
and you only use the si harness for the plugs
if it were that easy i think people would have been doing that for awhile now
Old May 27, 2007 | 10:40 AM
integrawow's Avatar
First, go to: http://www.ef-honda.com/ben/.
Secondly, select "Tech" from the menu.
Thirdly, select "MPFI and VTEC wiring" which is the fourth item under the "Engine" subcategory.
Lastly, read the article.
I hope this helps!
Old May 27, 2007 | 12:10 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEfGoKart &raquo;</TD></TR><TR><TD CLASS="quote">Ok i have searched and all I find is info on what to do if you have to convert/cut wires on your harness.
thats probably because thats the ONLY way to convert a DX to mpfi.....
Buddha214
14
May 26, 2014 03:10 PM
chafetzk
Aug 24, 2010 02:46 PM
91-CRX-Si
Oct 28, 2009 09:41 PM
91H4hatch
Sep 1, 2006 12:24 PM
OutLuDeD
Aug 16, 2003 06:30 AM
