HELP ASAP!!! blowing ECU fuses obd0-obd1 using distributor kings dizzy
So, doing OBD0-OBD1 on a DOHC ZC using a distributor Kings ECU. Have all wiring color matched and the Thick white wire going to the Yellow/Green. I noticed on the Dizzy kings Dizzy that on the main plug the white wire and the orange wire on the end without the empty pin are reversed. I keep blowing the 15A ECU harness. Any help appreciated, what the expletive did i do wrong?
still blowin Fuses with dizzy unplugged. Pulled the ECU and jumper out, no fuse popping. Tryin another ECU to figure out if its ECU or harness. Will obd0 ECU run on OBD1 DIZZY?
nmhuntr
Sep 30, 2009 05:56 AM
