PLEASE HELP!!!! would anyone have any idea on where the brake fluid is coming from????
Old May 25, 2007 | 08:46 PM
superhatchbackbros's Avatar
Default PLEASE HELP!!!! would anyone have any idea on where the brake fluid is coming from????
hey everyone, i just recently put rear disc conversion on my 89 hatch DX and i put a prop valve 40/40 and a new autozone master cylinder 13/15 i think it is.. i also redid my full brakes meaning rotors and carbon matelic brake pads all around and new calipers all around car... also SS brake lines.. now my problem is my pedel feels a lil smooshy not much but when i start the car up and then drive around the block and sit it i see a lil puddle of brake fluid under my car.. but its not coming from the front calipers nor the master cylinder... im trying to figure out where is coming from. its drippin somewhere and then runs down the underside near the driver side undercarrage and then it just drips and forms a lil puddle.. would anyone know where its coming from. i havnt seen anything leaking up top or around caliper etc.. could my brake booster be bad? a seal or something inside it? iif so is that hard to replace? or is thier any tricks i can try to find out where its leaking from? please help thanks in advanced H-T members..
Old May 25, 2007 | 10:56 PM
.Manny.'s Avatar
Touching My Member
Default Re: PLEASE HELP!!!! would anyone have any idea on where the brake fluid is coming from???? (superhat
did you put the ss lines in correctly.
retrace your steps, you'll find the leak
Old May 27, 2007 | 10:46 AM
anyone else? i cant seem to find the problem. anyone else have a simular problem l ike this? if so please tell me thanks
Old May 27, 2007 | 10:54 AM
rexracerboy's Avatar
Default Re: (superhatchbackbros)
Maybe check all of your connections? Sometimes you get to working and if you're playing music/drinking beer, and someone hollers at you through the garage window to make sure you don't forget to start the grill for dinner you overlook a nut here or there on accident.
Old May 27, 2007 | 01:12 PM
aight thanks.. im going to jack it up tomrrow and take off wheel and look everywhere.. like i said never had this problem so maybe i over looked something.. thanks again guys !!!
Old May 27, 2007 | 08:50 PM
It sucks but sometimes, even if you do have them tight, it might not have seated just right and then your brakes are under a lot of pressure so that might cause a leak (hopefully that's not the case cuz you might need to re-flare the line. If you have a friend out there with you, get him/her in the car mashing on the brakes while you check all the connections for leaks and then re-tighten each one.
First thing I would try anyway. Good luck
Old May 29, 2007 | 02:35 PM
thanks for more feedback.. imma try it all.
Old May 29, 2007 | 05:32 PM
SiRay13's Avatar
drive it around before you jack it up, so it will be easier to find the leak.
Old May 29, 2007 | 06:26 PM
thanks for the info.. deff drive it around then come home jack it up and look for the leak or leaks..
Old May 29, 2007 | 06:43 PM
Voodooboy520's Avatar
I had a similar problem. If your leak is comming from a connection (line to master cylinder or line to prop valve), it might be that there is a small piece of dirt in there. The two pieces of metal are being pressed together (thats how they seal) and if there is a speck of dirt in there, it will leak when you jam on the brakes.
Old May 29, 2007 | 07:55 PM
aight thanks.. i will deff try all these ..
Old Jun 7, 2007 | 10:37 AM
hey everyone.. drove my car around the block and came back and jacked it up.. i took wheel off and everything. i look up under and see nothing. i checked the master cylinder and all my hard lines and soft lines. i cant find no leaks or whatever going on.. its freaking me out, thier just a puddle under my car. it takes a lil while but it comes out, like i droped the car back down on the ground after feelin the resavoir back up and after l ike 10 mins i started to see driping underneath the car.. and now its all over the place, does anyone have this problem? or simular i need help.. what can or should i do?
Old Jun 7, 2007 | 10:41 AM
Donkey85's Avatar
you might have to take every wheel off and eye each of your lines and connections again........ if its still leaking thats the only way ur going to know where its comming from
Old Jun 7, 2007 | 10:47 AM
its leaking from the driver side i kno that thier no leaks anwhere else on the car.. and whatver going on its runing down to underneath the diriver side kick pannel underneath the car..
Old Jun 7, 2007 | 09:19 PM
hey guys.. i messed with my brakes and **** today and jacked up the car and nothing.. i let it sit for a while and it seems to be leaking from behind the brake booster on the car. what could be the problem. its leaking from the underside of tthe brake booster and driping underneath my car on the drive side.. is my brake booster bad? or could it be the rubber fitting on the master cylinder? someone please help.
hteg12
Jul 18, 2013 05:13 PM
bonspeed
Dec 20, 2009 12:34 PM
tazz29
Jul 9, 2008 10:52 AM
USDM-EK4*
Apr 4, 2008 07:50 PM
Jonathan_ED3
21
Sep 6, 2005 09:33 PM
