hearing inconsistant whinning noise now. not ac/ps/alt belts/pullies/pumps. comes from around inject
Old May 25, 2007 | 07:17 PM
mattsnooz's Avatar
Default hearing inconsistant whinning noise now. not ac/ps/alt belts/pullies/pumps. comes from around inject
any thoughts? its only noticibile around idle. it fluctuates with revs, while moving or while stopped. it seems worse when warmed up, and almost non existant when cool. it comes around the far right injector area. doesn't seem to be intake or vacuum. i know its a shot in the dark anyone could guess what it was. i use a hallow tube to narrow down where sound comes from and like i said its around where the far right injector is (looking from front of car) i tightened all intake mani bolts to make sure it wasn't an air leak. could it be internal like water pump or timing belt or tensioner? any input very much welcome, the noise is driving me bonkers. (more so)
Old May 25, 2007 | 08:21 PM
mattsnooz's Avatar
Default Re: hearing inconsistant whinning noise now. not ac/ps/alt belts/pullies/pumps. comes from around in
bump please. could it be timing belt or water pump? manual tensioner. anything i could do to know for sure?
thanks in advance
Old May 25, 2007 | 09:01 PM
Maharajamd's Avatar
I don't know how the tbelt or tensioner would cause I whining noise, but that is what a water pump will do when the bearing starts to go...
Old May 25, 2007 | 09:27 PM
PWRDbyHseries's Avatar
if im not mistaken the timing belt will make a whining noise if it is too tight, i have to replace my auto tensioner with a manuel 1 to fix my problem. Timing belt is my guess
Old May 26, 2007 | 06:02 AM
mattsnooz's Avatar
Default Re: (PWRDbyHseries)
it seems to only happen after warmed up. its comming from timing belt side, but i put a scope to timing belt cover and its quite. it comes from around the intake or fuel rail. is there anything in there that would whine or whirrrrr after warming up?
NathanDC4
Mar 27, 2016 11:43 PM
jaydmbb6
Jan 31, 2006 08:02 PM
riceburners1
13
Jun 2, 2004 10:57 AM
Drew96EJ
Oct 30, 2003 01:48 PM
timbuktu
Mar 19, 2002 05:48 PM
