Solid CEL car wont start
Old May 25, 2007 | 02:52 PM
1 Fly SI's Avatar
Default Solid CEL car wont start
1991 CRX HF totally unmolested wiring
I was driving down the road the other night, and the car cut off.the main relay clicked and the check engine light came on. I pulled over and checked for codes,no codes,checked all fuses,changed the main relay and the ecu and still wont crank up. It turns over, but the main relay doesn't click the second time, the ecu doesn't flash,solid cel, and the fuel pump prime. So I leave it
I go back the next day check everything again,wont crank. I un hook the underdash fuse box,hook it bach up and it fired right up. I am on the way home and it cuts off again. I unhook the fusebox again and try it and it wont crank this time. I tow it home. The next day I try and it cranks right up. I turn it off.
So I crank it again the next day and let it idle in the driveway,after two minutes it shuts off.The main relay clicked like I turned off the ignition,solid cel. I leave it alone and do the same thing the next day it cranks up again, shuts off 2 minutes later with the same symtoms. No it wont even crank up for two minutes.Nothing.
The things I have done
1)Changed the ecu with three known good ones
2)Changed the main relay with three know good ones
3)Changed the under dash fuse box with a good one
4)Changed the ignition switch
5)Checked the thermostat grounds and they are good and tight,and used a volt meter to double check them. checked all grounds
6)I realized the tranny ground was unhooked from the recent clutch job and hooked it up. still nothing
Please help if you can. TIA
Old May 25, 2007 | 03:04 PM
was this rickys car...
the one that chase wire tucked
check the distributor
Old May 25, 2007 | 03:09 PM
1 Fly SI's Avatar
Default Re: (vega_box)
No its my hf with the sohc zc in it.
Why would the dizzy stop the fuel pump or ecu from getting power?
Old May 25, 2007 | 03:12 PM
24TEN's Avatar
PHANTOM MENACE
had the same problem on my corolla, it was my distributor.
have you checked to see if you are getting spark at all? generally speaking, first two things you should check for are spark and fuel. pull a plug wire and ground it to a shock tower bolt and have someone crank the engine for you.
Old May 25, 2007 | 03:16 PM
1 Fly SI's Avatar
Default Re: (24TEN)
I know I am not getting fuel, I will run out and check spark, But how will I get spark if the ecu isn't getting power?
Old May 25, 2007 | 03:18 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: (1 Fly SI)
It's a good question and I wish I had a direct answer. On my corolla I wasn't getting spark or fuel (checked spark with the grounded plug wire and pulled the fuel line off...separately of course ). I replaced my distributor and it fixed both.
Old May 25, 2007 | 03:56 PM
1 Fly SI's Avatar
Default Re: (24TEN)
Alright so it wasn'd the dizzy but you did point me in the right direction,so I am going to paypal you some money when I get home on monday. I took the dizzy off and saw a plug pinched between the tranny and the block. everything is hooked up so I don't know where it goes. I can't see the plug because it is inside the tranny. I pulled on the wires and they broke flush at the tranny. It is three wires, green/white, yellow/white, yellow. anyone know where these go? they are under the dizzy where the harness splits to go to the dizzy and o2 ect. I am thinking they have something to do with the old hf motor(It has a sohc zc in it now).
Modified by 1 Fly SI at 8:13 PM 5/28/2007
Old May 25, 2007 | 03:57 PM
awww heeelllll naaahhh
i said check the distributor first
thats fukled up y0
freakn scammer
your no longer in the EF sQaud
Old May 25, 2007 | 04:39 PM
civicandy's Avatar
I was gonna say check the ignitor. I had that go out once, and the car shut down.
Old May 25, 2007 | 06:34 PM
kylefakesi-r's Avatar
Default Re: (civicandy)
well green with a white tracer is a honda standard color for 5volt sensor source. so if you had a 5v off of the ecu blatantly shorted to ground you could be stalling etc whenever it made contact. chassis vibration will do some strange ****.
yel and yel/wht. i gotta look at a diagram to break down teh possibilities as to what those wires may be for (yel/wht is commonly a 12v sensor source).
Old May 26, 2007 | 09:12 AM
thenick's Avatar
Ignitor?
Old May 26, 2007 | 09:25 AM
24TEN's Avatar
PHANTOM MENACE
Any updates today?
Old May 26, 2007 | 12:05 PM
89hatcher's Avatar
i think the green/white could be your map sensor ground, yellow/white map 5v, and yellow i dunno maybe injector #4 hope this helps.
Old May 26, 2007 | 05:58 PM
1 Fly SI's Avatar
Default Re: (89hatcher)
I'm not at the house today,but I did get it to crank. Where the engine harness goes under the dizzy,it branches up to the dizzy,then along the top of the tranny going to the water temp sender,o2,reverse signal,ECT. Well each plug branches off the harness in its own seperate loom,and there is a seperate plug in between the tranny and block. I don't know what the plug goes to as everything is hooked up where it needs to be. It is a three wire plug. the car runs with no cel, so I don't know.
I remember when I put the zc in the car I used the hf engine harness and there was 1 extra rectangular plug. I will figure it out on monday and let everyone know.
Thanks Honda-Tech
Old May 26, 2007 | 06:05 PM
Default Re: (thenick)
for paypaling me $83.54 for helping you out.
Thanks man
Old May 26, 2007 | 07:08 PM
nihad's Avatar
hey i also have a wiring problem and dont know where it is. The car cranks over and every think some times it is solid cell some times it is cel 20. I am loosing power somewere and dont know where when i step on the break it feels like the battery is low but it is not I have taken all the interior out and cant find nothing thats is wrong if any of u guys have had problems with power loss help me please.
Old May 27, 2007 | 12:57 AM
thenick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vega_box &raquo;</TD></TR><TR><TD CLASS="quote"> for paypaling me $83.54 for helping you out.
Thanks man</TD></TR></TABLE>
WTF?
OP check this out: http://www.g2ic.com/tegtips/engine/10.html
Old May 28, 2007 | 01:18 PM
1 Fly SI's Avatar
The wires were for the egr valve. Im glad this motor doesn't have one.
Old May 28, 2007 | 01:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Fly SI &raquo;</TD></TR><TR><TD CLASS="quote">The wires were for the egr valve. Im glad this motor doesn't have one.</TD></TR></TABLE>
for real
so what happen after that??
Old May 28, 2007 | 01:24 PM
did you check to see if the wires were still "hot". short to ground will cause problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">hey i also have a wiring problem and dont know where it is. The car cranks over and every think some times it is solid cell some times it is cel 20. I am loosing power somewere and dont know where when i step on the break it feels like the battery is low but it is not I have taken all the interior out and cant find nothing thats is wrong if any of u guys have had problems with power loss help me please.</TD></TR></TABLE>
code 20 is eld. you have a bad alternator most likely.
Old May 28, 2007 | 01:41 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: Solid CEL car wont start (vega_box)
wow WTF
Was it necessary to quote him?
Old May 28, 2007 | 01:43 PM
Default Re: Solid CEL car wont start (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
Was it necessary to quote him?</TD></TR></TABLE>
LOL
nah
Old May 28, 2007 | 02:51 PM
1 Fly SI's Avatar
LOL
nah</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Old May 28, 2007 | 03:55 PM
ahahahahaha
always around when you need him
JDM_SOHC
19
Dec 20, 2011 04:15 PM
SaveDaNoob
Jul 7, 2011 07:06 PM
tlarimer
Jul 20, 2009 03:18 PM
illestrolla247
Apr 4, 2005 06:24 PM
thecorey
Jun 8, 2003 08:22 AM
