need help installing hawker odyssey battery bracket
Old May 25, 2007 | 01:53 PM
coot_er's Avatar
Default need help installing hawker odyssey battery bracket
i bought the battery and the pre-made fancy aluminum bracket. i want to install it right underneath were the stock location is. i cant figure out how to get a drill in there and if i did how would i put a nut on the back? i would have it welded in but i would rather not incase i would need to take the engine out, or even replace the battery since the bracket basically seals it in. basically im looking for a how to.
Thanks
Old May 25, 2007 | 02:07 PM
nihad's Avatar
Default Re: need help installing hawker odyssey battery bracket (coot_er)
where can i get one and how much.
Old May 25, 2007 | 02:38 PM
coot_er's Avatar
Default Re: need help installing hawker odyssey battery bracket (nihad)
http://www.gotbatteries.com/it...PC680
Old May 25, 2007 | 02:43 PM
turbohappy's Avatar
There are a few bolt-holes down there already for the stock battery tray and for the stock ground wire. I just made my own bracket for my PC310 and attached it to them, no drilling.
Old May 25, 2007 | 02:46 PM
coot_er's Avatar
Default Re: (turbohappy)
good idea, the thing is i already bought the bracket and i don't have fab skills.
Old May 25, 2007 | 03:29 PM
Crx Jimmy's Avatar
Default Re: (coot_er)
drill holes and use a nutsert I would recommend buying the nutsert tool but its like $70 with the proper mandrel. You can just buy the nutserts which are cheap and use the method here. http://www.broncofix.com/Tech/nut/nut.htm
Old May 25, 2007 | 07:32 PM
coot_er's Avatar
Default Re: (Crx Jimmy)
are there any other options?
Old May 25, 2007 | 08:27 PM
Tippyman's Avatar
Autoworks did it. Lets hope he chimes in.
PS Cool tool, BTW.
Old May 26, 2007 | 05:19 AM
coot_er's Avatar
Default Re: (Tippyman)
any one else?
Old May 26, 2007 | 07:22 AM
Wes V's Avatar
Use a 90 degree adapter for a drill motor to drill the holes required and then install nut-serts (as noted above)
Wes
Old May 26, 2007 | 09:12 AM
GSRCRXsi's Avatar
Default Re: (Wes V)
i just drilled and tapped the holes and used bolts works fine
Old May 26, 2007 | 05:48 PM
coot_er's Avatar
Default Re: (Wes V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">Use a 90 degree adapter for a drill motor to drill the holes required and then install nut-serts (as noted above)
Wes</TD></TR></TABLE>
oh, i didn't know this adapter existed. pics of the install?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">i just drilled and tapped the holes and used bolts works fine</TD></TR></TABLE>
how did you just use the bolts? drill completely through frame?
Old May 26, 2007 | 07:21 PM
Crx Jimmy's Avatar
yes drill thru the frame its not thick at all. they also make 90 degree drills for this job
Old May 27, 2007 | 07:52 AM
Wes V's Avatar
coot_er;
I don't have a photo of a 90 degree adapter, but it's pretty much what it sounds like.
You "chuck" it into your drillmotor and there is a 90 degree gear unit within it for it's chuck that points off to the side.
They tend to flop around while drilling, so you have to drill slowly.
You can also buy drill bits that are shorter in length for really close areas.
Check out Harbor Freight to buy one (it's my guess that they have them). Unless you do a lot of fabricating, you will most likely only use it once or twice, and as such a cheap one will get you by. (I've used mine only once)
Another thought would be to just pop rivet the battery box to the frame rail.
Wes
Old May 27, 2007 | 07:24 PM
Tippyman's Avatar
Default Re: (Wes V)
Wouldn't a self-taping screw work fine?
Old May 27, 2007 | 08:02 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't a self-taping screw work fine?</TD></TR></TABLE>
That's what I plan to use on mine. A few of them, but i don't see why they wouldn't hold.
Old May 28, 2007 | 06:03 PM
coot_er's Avatar
do i still need to drill holes for self tapping screws? are these screws reusable?
Old May 28, 2007 | 06:23 PM
Crx Jimmy's Avatar
the self tapping screws have a drill point head. they drill the hole as they go in. I would rather use some large steel rivets than these though.
ca-rs
Jun 16, 2010 12:50 PM
ef9robert
Nov 11, 2008 09:54 PM
SiR18EG
Mar 23, 2008 03:58 PM
