rotor removal hole
from an older thread while searching:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey »</TD></TR><TR><TD CLASS="quote">don't use a hammer and a screwdriver for the phillips. get an impact driver for 10 bucks.
as far as the seized rotors, if you look at the rotors, you'll see a threaded hole. find a bolt that fits that hole and screw it in. this will pop the rotor off. unfortunately i can't remember what the thread and pitch are, but if i had to guess i'd say 6mm x 1.0.</TD></TR></TABLE>
does anyone know the exact dimensions of the bolt ill need? im 99% sure i have stock rotors
im planning on replacing my pads/rotors soon, and i want to make sure i have all the tools needed for a smooth removal and replace. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illusion »</TD></TR><TR><TD CLASS="quote">does anyone know the exact dimensions of the bolt ill need? im 99% sure i have stock rotors
It looks like this:
It looks like this:
rice a roni
35
May 16, 2006 05:34 PM
