clutch repair
ok when remove the trans to get to the clutch it looks like my trans has 2 parts 2 it...
is so what part do i remove to replace the clutch? remove the tranny from the motor?
ht rules
ht rules
Yes, the transmission itself is a split case design. You want to remove the 'whole' transmission, instead of just 1/2 of it, to get at the clutch. Yes, the starter needs to be removed. It's really just the lower bolt though, because the upper only threads into the transmission itself.
