Stock GS-R and LS fuel pumps interchangeable?
Old May 25, 2007 | 09:17 AM
White98LS's Avatar
Default Stock GS-R and LS fuel pumps interchangeable?
This is probably a dumb question and probably a "yes", but just wanted to make sure before I bought one... is a stock GS-R fuel pump interchangeable with an LS one?
And if so... anyone have a GS-R pump for sale?
EDIT: I already have an adjustable FPR.
Old May 25, 2007 | 09:28 AM
__oversea's Avatar
Default Re: Stock GS-R and LS fuel pumps interchangeable? (White98LS)
look here if they have same part #'s
http://www.acuraautomotivepart...e.htm
Old May 25, 2007 | 09:29 AM
White98LS's Avatar
Default Re: Stock GS-R and LS fuel pumps interchangeable? (Kangpreza)
Well I know they are different parts, the GS-R pump flows at a much higher rate than the LS one, so they will have different part numbers. I'm wondering if I can swap a GS-R pump into my LS though without modification. My pump might be shot and I could use a somewhat higher-flow pump (running 47psi at idle, non-VTEC B18B with cams).
wreckedmyteg
Feb 13, 2005 09:13 AM
blu2ksi
Feb 4, 2004 01:30 PM
GSRswapandslow
Oct 11, 2003 10:56 AM
soopafly828
Feb 17, 2003 12:38 AM
wdyno
Nov 30, 2001 07:20 AM
