oil breather box leaking oil........ already replaced o-ring? anyone else?
replaced the o-ring and its still leaking i have taken it out a couple times to make sure the o-ring is properly seated and it is so im not sure what to do now?
anyone else have this issue? i was thinking about just running some honda bond around it but wasnt sure? its weird and it smells like crap bc it drips on my collector!
When I installed my catch can, i had to plug up that hole for the black box with a plug...
i used honda bond around it and now its basically baked on there and dry
uhh i got a custom one with my custom catch can. i just reused the rubber o ring, applied a coat of hondabond around it and just tapped it in slowly...a little bit of it oozed out after i did that and i was able to use my finger to get it all the way around the seam (kinda like when you caulk a bathroom tub... )
guess nobody else has any solutions? im not talking about any catch can setup im talking about the OEM black box leaking......... guess i will just hondabond it in there........ man that stuff works wonders
i had this same problem, i had replaced the o ring. turns out that the bottom of the box where there was a seam that was supposed to be welded was cracked. and the whole time the oil was leaking from there, instead of the o-ring. i think it was from the tab where the bottom most bolt goes... hope this helps, dont have any pics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSiR »</TD></TR><TR><TD CLASS="quote">i had this same problem, i had replaced the o ring. turns out that the bottom of the box where there was a seam that was supposed to be welded was cracked. </TD></TR></TABLE>
Happened to my breather box on my '97 as well. Where the lower mounting bracket joins the box, there seems to be a couple tack welds and thats about it.
I took a breather off of a spare motor I had ('00 JDM ITR) and lone behold, the bracket has full welds around the joining area. Go figure huh? So it looks like JDM motors have a better breather box as well!
Anyhow, go look for a JDM ITR breather box, it should last the life of your car.
hmmmmm i will take it back off and check it out a little better....... ill try to weld it up and seal it first but if i have to get another i will try to find the jdm one i guess
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">
Same with my 97. I just replaced it with a new one from the dealer.
phelpsj2
Oct 30, 2012 12:31 PM
H4CRXSi
Feb 22, 2010 03:53 PM
