OPINIONS!!!! B16 DC2
Old May 25, 2007 | 08:10 AM
B16_DC2's Avatar
Default OPINIONS!!!! B16 DC2
hello, i have a dc2, that has a b16 obo1 in it.
some people says that i is goin to be slow as hell.
but i just beat a the 2000 model prelude with it.
i dont know if its just me but i cant really believe it.
supposebly, this engine has type r cams and pistons, valve springs,
etc.
well i just need some opinions.
and how do u check your cams if they are type r or not?
and the pistons?
let me know.
Old May 25, 2007 | 08:27 AM
VTECth1s's Avatar
Default Re: OPINIONS!!!! B16 DC2 (B16_DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">hello, i have a dc2, that has a b16 obo1 in it.
etc.
and the pistons?
let me know.</TD></TR></TABLE>
Someone else correct me if I'm wrong but the ITR and b16 cams have a different lift and lobe sizes, also check if the stock cam gears have an imprint of pr3 which represents b16 if not then its something else. And the Pistons, you'll have to take the head off and the markings will be on the pistons pr3 or p30 for b16's and type-r would have p73. Lotta work just to see whats inside the motor.
Old May 25, 2007 | 09:07 AM
AllMotorDan's Avatar
i have a b16a w/ itr cams i/h/e in my DC and its not bad at all but my gsr block is being built as we speak.
Old May 25, 2007 | 10:47 AM
St Jimmy's Avatar
* B A N N E D *
Alot of people on here have little to no knowladge and just jump on bandwagons and then all this false info spreads. A B16 isnt going to make an integra slow. They are just as quick as a integra with an b18a/b. I have had a b16 integra and a b18 integra and they both ran a 15.7 stock.
Old May 25, 2007 | 10:51 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: OPINIONS!!!! B16 DC2 (St Jimmy)
Just so I can say I helped.
http://www.ff-squad.com/tech/temp/VtecCams.htm
Thats everything you need to know in identifying the cams you have.
Old May 25, 2007 | 11:49 AM
deadline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Alot of people on here have little to no knowladge and just jump on bandwagons and then all this false info spreads. A B16 isnt going to make an integra slow. They are just as quick as a integra with an b18a/b. I have had a b16 integra and a b18 integra and they both ran a 15.7 stock.</TD></TR></TABLE> yes
Old May 25, 2007 | 05:49 PM
Rajin's Avatar
Default Re: OPINIONS!!!! B16 DC2 (deadline)
People only say anything because the B18 produces more torque.
Thats why they say the torqueless b16s are slow.
Old May 25, 2007 | 08:56 PM
1.8L_allmotormilitia's Avatar
ewww b16 dc2= slower then a LS!!
Old May 25, 2007 | 09:36 PM
whitepandaeg6's Avatar
Default Re: OPINIONS!!!! B16 DC2 (1.8L_allmotormilitia)
a b16 in an integra rs will not be slow it will actualy be faster than an a 1999-2000 civic si an thats because an dc2 rs weights 2529 ponds as compare to the civic si 2616 pounds so do the math and you will see with one woud be faster now an integra ls
weights 2649 pounds not alot compare to an si. an integra rs is even lighter than a itr
with weights 2579 pounds
Old May 25, 2007 | 11:10 PM
ballmode's Avatar
If its modded it should be faster than the B18
Old May 26, 2007 | 07:34 AM
Madness's Avatar
Default Re: OPINIONS!!!! B16 DC2 (VTECth1s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s &raquo;</TD></TR><TR><TD CLASS="quote">Someone else correct me if I'm wrong but the ITR and b16 cams have a different lift and lobe sizes, also check if the stock cam gears have an imprint of pr3 which represents b16 if not then its something else. And the Pistons, you'll have to take the head off and the markings will be on the pistons pr3 or p30 for b16's and type-r would have p73. Lotta work just to see whats inside the motor.</TD></TR></TABLE>
B16 & ITR cams are different. You will have to pull the valve cover and cam caps to see which cams you have. Check out FF-squad's link to figure out which they are.
Cam gear stamps won't tell you anything.
Try doing a compression test, and bring your results back here.
Old May 26, 2007 | 07:41 AM
Madness's Avatar
Default Re: OPINIONS!!!! B16 DC2 (Madness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitepandaeg6 &raquo;</TD></TR><TR><TD CLASS="quote">a b16 in an integra rs will not be slow it will actualy be faster than an a 1999-2000 civic si an thats because an dc2 rs weights 2529 ponds as compare to the civic si 2616 pounds so do the math and you will see with one woud be faster now an integra ls
with weights 2579 pounds </TD></TR></TABLE>
This is so true. People think a B16 Teg will be a pig, but the same people think a 99 Si is a friggin racecar.
FatalCrixer
Apr 26, 2010 12:33 PM
boostedefhatch
Jan 29, 2009 08:45 AM
Weel
Feb 9, 2008 06:07 PM
thirteen20CRXSi
Dec 27, 2006 04:51 AM
