stage 3 cams
Old May 25, 2007 | 07:45 AM
B16A CRX's Avatar
Default stage 3 cams
I have Ctr pistons with full valve train. Is it possible to put Skunk2 Pro 3 cams. Its a B16 btw
Old May 25, 2007 | 07:52 AM
dr_latino999's Avatar
Default Re: stage 3 cams (B16A CRX)
Possible, of course. It's up to you if you want to do it. What's the compression with the CTR pistons?
Old May 25, 2007 | 08:34 AM
goforbroke's Avatar
MEAT PATTY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A CRX &raquo;</TD></TR><TR><TD CLASS="quote">I have Ctr pistons with full valve train. Is it possible to put Skunk2 Pro 3 cams. Its a B16 btw</TD></TR></TABLE>
You want to run Pro 3's in a relatively stock b16!? I think you need to do a little research. I'm not trying to come off like a ***** but b16's don't have enough displacement to run pro3 to the level were they need to be. You probably want to look at pro1's and even that might be pushing it........
Old May 25, 2007 | 10:00 AM
turbodcivic510's Avatar
Old May 25, 2007 | 11:24 AM
B16A CRX's Avatar
Default Re: (turbodcivic510)
But my B16 isnt stock i do have Springs and retainers and as for the compression for the CTR pistons i havent found out yet but the skunk2 pro3 cams recommend to have atleast 12:5:1 im guessing thats what ill have since i also have a 2 layer headgasket.
Old May 25, 2007 | 11:29 AM
running stock honda pistons isnt going to make your engine anywhere near a "race" application. therefor your c/r will be far below the level of running pro3's
Old May 25, 2007 | 11:38 AM
B16A CRX's Avatar
so even if the CTR get me to the 12:5:1 compression i cant put the cams on?
Old May 25, 2007 | 11:42 AM
you basically have a ctr motor, which is stock.
build a crazy race motors, with some super high comp pistons then buy some pro3s
Old May 25, 2007 | 11:46 AM
team1320 B20eg's Avatar
Yes it is possible . I have a b18 with ctrs too, my b18 it cut 25 over for them. I am using crower stage 3 cams.
Old May 25, 2007 | 11:49 AM
B16A CRX's Avatar
Default Re: stage 3 cams (team1320 B18c1eg6)
Whats the compression with the CTR in you B18. where did u buy your CTR pistons
Old May 25, 2007 | 12:01 PM
My compression is 12:5:1, but to get that compression I cut 30k off my head, I got my CTRs from one of my boys that had them at that time.
Old May 25, 2007 | 12:08 PM
B16A CRX's Avatar
and u have pro3 skunk2 how long have u ran it for.
Old May 26, 2007 | 06:17 AM
goforbroke's Avatar
MEAT PATTY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team1320 B18c1eg6 &raquo;</TD></TR><TR><TD CLASS="quote"> I am using crower stage 3 cams.</TD></TR></TABLE>
These are TOTALLY different then pro3's. On a completely different level.
Old May 26, 2007 | 06:48 AM
Raptastik87's Avatar
He said he had crower stage 3, his are a harsh cam, but the pro 3's are a little more of an all out race cam, plus he said he had a b18, his strokes different from your b16 so the compression on his motor will probably be different from yours.
Old May 26, 2007 | 06:52 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: stage 3 cams (Raptastik87)
you have a b16 with ctr pistons and you don't know your compresion.. so i take it you didn't build the engine or learn anything much about it other than cool words like ctr and valvetrain.. ekk this is what happens when you don't do your homework...
good luck picking out cams
Old May 28, 2007 | 01:34 PM
B16A CRX's Avatar
Default Re: stage 3 cams (GarageAlchemist)
thats because i all the research i have done gives me different answer. im waitin for my CTR pistons to come in so i can get the compression measured.
racing_reject_001
20
May 10, 2009 04:38 AM
bosco500
Mar 11, 2008 09:37 AM
BG-Teg
27
May 14, 2007 02:27 PM
EM1VtecSi
Aug 10, 2005 04:50 PM
lke2drvgsr
Feb 17, 2004 11:17 AM
