B18C1 Help Me.. Guyz
Old May 25, 2007 | 02:29 AM
Razalie's Avatar
Default B18C1 Help Me.. Guyz
Sorry about that. Below my entire question is:
1. Cable pug OEM or after market which one better? If after market which brand do you recommended?
2. Spark plug OEM or after market which one better? If after market which brand do you recommended?
3. The size of piping do you recommended... either 2'2" inch or 2'5" Which one you recommended?
4. Engine oil chosen either 5W50, 10W50 etc. Which one you recommended?
5. Sport air filter which is the better...OEM or after market? If after market which brand do you recommended?
Here... I gave to you my engine spec:
Engine B18C1 not Type R (Integra GSR).
Automatic transmission.
Everything OEM... Such as piston, cam, ecu etc.
Thank You. Have a great to you...
Old May 25, 2007 | 02:52 AM
gator88's Avatar
Default Re: B18C1 Help Me.. Guyz (Razalie)
Plug, NGK
Plug Wires, NGK but they only come in blue, not reason enough not to use them
I say 2.5 inch piping thinking u are going custom exhaust?
I run 10w30 Full synthetic AMSOIL or REDLINE
K&N Drop in Flat Panel Air filter, with silencer tube removed, some swiss cheese their box with a hole saw or big drill bit
If you are doing plugs and plug wires, might as well spend a few dollar more and get a new cap and rotor and be all set ignition wise. Are you doing a full tune up? IF so might wanna check out a thread I made a short time ago...https://honda-tech.com/zerothread?id=1957013 tells ya all i did for a tune up
Old May 25, 2007 | 04:09 AM
Razalie's Avatar
Default Re: B18C1 Help Me.. Guyz (gator88)
A lots of tank you guyz.. for the information.. i relly apriaciate.. hv a gr8 to u
Razalie
Jun 13, 2007 05:17 PM
Razalie
May 25, 2007 06:49 AM
smikeL
Mar 9, 2005 08:10 AM
B18C R Spec
Jul 19, 2004 01:58 PM
luckyzz
Apr 26, 2004 05:38 PM
