Need a lil help...
Old May 24, 2007 | 11:51 PM
taking-back-sunday07's Avatar
Default Need a lil help...
I'm finally building my D15B and I'm on the lookout for parts...I was needing pistons and rods for the turbo setup...My question is,will this kit I found fit my motor? I know the bore is right (75mm) but it doesnt say anything about the stroke...Any help would be appreciated
http://cgi.ebay.com/Honda-Civi...wItem
Old May 25, 2007 | 12:01 AM
njn63's Avatar
Default Re: Need a lil help... (taking-back-sunday07)
d15b vtec or d15b2/d15b6/d15b7/etc?
Old May 25, 2007 | 12:17 AM
Default Re: Need a lil help... (njn63)
D15B VTEC...its a JDM import
Old May 25, 2007 | 08:59 AM
TTT
Old May 25, 2007 | 11:00 AM
ludesrv's Avatar
Ebay turbo kits = GARBAGE!
IF you are looking at EBAY stuff for turbo, you need to go to forced induction forum and read up on other peoples turbo builds (it's fun and interesting, plus you will learn LOTS).
Old May 25, 2007 | 11:06 AM
IT GUY's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Ebay turbo kits = GARBAGE!
IF you are looking at EBAY stuff for turbo, you need to go to forced induction forum and read up on other peoples turbo builds (it's fun and interesting, plus you will learn LOTS).</TD></TR></TABLE>
didn't read the post did you? he was asking about rods and pistons... the ebay link is even to an auction for rods and pistons... the only thing he said about a turbo setup is that he needed rods and pistons for it..
Old May 25, 2007 | 11:42 AM
garageEF's Avatar
what the hell are you talking about?
and cant you swap a d16 crank in to up the displacment?
Old May 25, 2007 | 12:24 PM
IT GUY's Avatar
Default Re: (garageEF)
if you swap a D16 crank in, then the rods have to be custom length... otherwise, like I said you'd end up with the pistons sticking out of the block
Old May 25, 2007 | 01:19 PM
D16Z6racing's Avatar
ask the seller.
isn't the D15B a D15 block, with a Z6 head?
Old May 25, 2007 | 07:47 PM
Default Re: Need a lil help... (D16Z6racing)
yes it is..
Old May 25, 2007 | 07:49 PM
Default Re: (IT GUY)
Ah, but I did some research and found this quote on multiple websites... "·D15Z1 and D15B motors have a rod that is the same length as a D16. Other than the rod length, the rest of the bottom end is D15 spec (i.e. rod and crank bearings). D15B has D16 sized rod journals. D15B uses the same p28 rods that the D16z6 does. All other D15s have smaller rod journals." Any other opinions? If this kit will indeed fit, then I need to go ahead and buy it..
Old May 25, 2007 | 09:33 PM
danmdevries's Avatar
Default Re: (taking-back-sunday07)
Do you really need to have two identical threads?
ek4u2nv
Apr 30, 2009 08:22 PM
H22CIVICJDM
Feb 23, 2007 04:03 PM
Dj Skidz7
Sep 2, 2006 07:35 PM
Syke Fu
Jul 9, 2005 05:12 PM
ferby
16
Jul 3, 2005 01:43 PM
