Possible Clutch & Flywheel Problem?
Old May 24, 2007 | 09:39 PM
Mr.Luder's Avatar
Default Possible Clutch & Flywheel Problem?
Well when I first got my car, the throw out bearing had to be replaced so I bought an XTD stage 1 clutch kit with the pro-lite 12lbs flywheel. Everything worked fine after the replacement but at 4k rpm there was a strange noise. It's like a harsh spinning noise like something is turning un evenly. Kinda like a whirling noise only at 4k rpm. The car never made this noise before the clutch replacement. So than I changed the clutch and flywheel back to stock with a luk clutch kit and my stock flywheel turned down to 18lbs. It's still making that noise at 4k rpm and now its starting to do it between shifts. The ones in between shifts goes away after the car go smooth again. What could this be? Has anyone had this problem before? Could it be that I had an unbalanced flywheel both times? Thanks
Old May 24, 2007 | 10:13 PM
93sivtec's Avatar
Had the same thing happen to me,xtd......same whirling noise and everything,and no clue what the noise is.I was guessing my thrrow out bearing,but its been replaced,so idk.
Old May 24, 2007 | 10:29 PM
Mr.Luder's Avatar
Default Re: (93sivtec)
same here....i'm thinking its the flywheel...the xtd flywheel was shitting so it made that noise and my stock flywheel had a few warp spots on them and i just turned it down to 18lbs and didn't mic it so maybe thats it?
Old May 25, 2007 | 09:22 AM
93sivtec's Avatar
Yeah I still have that crappy flywheel in my car,maybe when I do the clutch this summer,I will swap back in my oem flywheel and see if it helps.
Old May 25, 2007 | 09:29 AM
Maharajamd's Avatar
I have heard nothing but bad press about the XTD setups. Some say the stage 3 or higher are alright though...
I just did mine, Exedy Stage 1, OEM fly, and I'm loving it. Screw lightweight flywheels, I'd like to keep the little torque that I have lol..
Old May 25, 2007 | 01:47 PM
Mr.Luder's Avatar
Default Re: (Maharajamd)
yea i was actually one of those people who gave it a bad review.
but i also think i'm the first to post about this problem?
RobbieDB
Jun 27, 2012 02:56 PM
98GeeYes-Are
Feb 14, 2004 11:15 PM
selectivebeef
Jul 1, 2003 08:27 PM
