help: timing belt change, info needed
Old May 24, 2007 | 08:39 PM
waz88's Avatar
Default help: timing belt change, info needed
Hello, I am changing my timing belt on an 97 gsr, and am wondering is it better to get aftermarket cam gears in place of stock ones? What changes will I feel if I do put cam gears.
Now when I change the timing belt, I am going to also get water pump and valve cover gasket. Is there anything else that I should do when I have all of it exposed/open, because I am going to do turbo set up (t3/t4 57 trimm .63a/r).
Thnx 4 the help
PS: PLEASE SOMEONE TELL ME HOW TO REPLY TO BUY STUFF ON CLASSIFIED FORCED INDUCTION I HAVE MEEN MEMBER FOR 2 MONTHS OR MORE AND I NEED TO BUY TURBO STUFF ASAP.
Again thnx...
Old May 24, 2007 | 08:48 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: help: timing belt change, info needed (waz88)
Unless you get cams, or wanna play with the timing, you won't get anything out of dif cam gears.
You should also be able to post in the marketplace, you're not a trialuser now.
Old May 24, 2007 | 09:01 PM
waz88's Avatar
Default Re: help: timing belt change, info needed (CleanLikeJdm)
Man u dont know how many time I tried, I got soo pissed by the deals that I am losing Everytime I post a reply, says u dont have permission, and I also subscribe 2 the forum. Plus no one to ask ( hondatech member) such as through e-mail or something anyways...
thnx 4 reply
Old May 24, 2007 | 09:15 PM
Hype-R Stalker
You should be good now, it's 15 days, and so many posts.
So all the posting, and pm'ing should work fine for you.
vlc92189
Feb 21, 2007 05:46 PM
cooteg6
May 9, 2006 03:12 PM
DIYMIKE
Mar 10, 2004 06:48 PM
Tomakit
Oct 26, 2001 02:40 PM
